Author Topic: Edit Coordinate Systems  (Read 3601 times)
dfarris75
« on: June 19, 2008, 10:57:09 AM »
I have a drawing set up in NAD 27 Zone 17 with a dem surface added. I want to bring in doqqs which are in NAD 83 FL East Zone via data connect. I was under the impression that the Edit Coordinate Systems would allow me to do this, but they (doqqs) just plop right into the same place. Am I using the tool incorrectly or must I create a separate .dwg with the doqqs in their zone and then query that .dwg in???
dfarris75
Re: Edit Coordinate Systems
« Reply #1 on: June 19, 2008, 11:01:30 AM »
BLING!!! I figured it out. I was using it incorrectly. I was inputting the dem file coord zone in the Edit Coord... deal when I was supposed to be inputting the sources coord zone...
Thanks for all your help! :lol:
Dinosaur
« Reply #2 on: June 19, 2008, 11:04:21 AM »
sure . . . any time . . . glad to be of service  :-D
dfarris75
« Reply #3 on: June 19, 2008, 11:05:30 AM »
Hehe. Now I guess my next question is, why are DEM's so squarish in nature? My contours are all jagged.
Dinosaur
« Reply #4 on: June 19, 2008, 11:13:28 AM »
they are based on a grid of given resolution . . . the entire area of each square on that grid is assumed to be at the same elevation - kind of like a bunch of building blocks stacked in columns of different heights
dfarris75
« Reply #5 on: June 19, 2008, 11:51:08 AM »
Hmmm. And I guess there's really no way to smooth them out so they're a little more aesthetically pleasing.
Dinosaur
« Reply #6 on: June 19, 2008, 11:57:07 AM »
You might try some of the smoothing options or min / max triangle lengths in your surface style.  I have neither working C3D nor DEM data right now to check.
dfarris75
« Reply #7 on: June 19, 2008, 12:04:02 PM »
Smoothing is on and set around 7. I don't think adjusting max. triangles will help. Oh look. It's lunch time.
Dinosaur
« Reply #8 on: June 19, 2008, 12:09:29 PM »
The problem is you have a lot of hard data sitting exactly on a contour elevation.  I have no clue if this will have any effect, but what happens if you raise or lower the entire surface some percentage of a foot?  This is very low precision data anyway.
Jeff_M
  • C3D user & customizer
« Reply #9 on: June 19, 2008, 12:25:37 PM »
I had the same problem (I guess we all would if we all used DEM's...) so I wrote a little lisp that weeds the contours and gives a decent looking contour. However, I found that using Google Earth gives just about the same results and is far easier than getting the DEM's.
I'll post the lisp if you'd like to give it a shot.
dfarris75
« Reply #10 on: June 19, 2008, 12:38:28 PM »
Sure. What the heck. May as well have it available in the lisp arsenal anyway. :wink:
Jeff_M
« Reply #11 on: June 19, 2008, 01:18:26 PM »
OK, here ya go. The lisp to load is "weed-nineties.lsp" and the command is "desquareconts". Select the contours to smooth out and wait while it works. It isn't ideal, but for the job I created it for the client was happy.
dfarris75
« Reply #12 on: June 19, 2008, 01:55:42 PM »
And to verify, this is for Civil 3D surfaces or no?
dfarris75
« Reply #13 on: June 19, 2008, 02:04:45 PM »
Doesn't appear to...
Jeff_M
« Reply #14 on: June 19, 2008, 02:28:22 PM »
Oh, my apologies I should have clarified......
Create your C3D surface from the DEM,
Use the Style for the contour display as you please,
Extract the contours,
Use the lisp on the resulting polylines,
Create a new surface from the modified plines.
Set the original DEM surface to No_Display
Like I said, Google Earth is a bit easier :-)
