Author Topic: pass BYLAYER to entmake  (Read 2231 times)
curmudgeon
« on: August 20, 2009, 10:50:50 AM »
I am going to the block table to get the definitions for each entity in a block, and then I want to entmake each entity.
I am recreating the explode command so I can pass extended data from a block to some "undisclosed location".
first test, there are entities with linetype BYBLOCK, and some entities with a forced colour. I tried this:
(entmake (list '(0 . "LINE")
  '(100 . "AcDbEntity")
  (assoc 8 data)
  (if (assoc 62 data) (assoc 62 data))
  (assoc 6 data)
  '(100 . "AcDbLine")
  (cons 10 (tran 10))
  (cons 11 (tran 11))
so that if the colour is forced, it will recreate it correctly. but when it is bylayer in the block definition there is no (assoc 62 data), and it returns a nil in the middle of my list - which entmake really does not like so very much. obviously, the (assoc 6 data) will have the same problem.
...................... sometimes stating the problem is all I need. now I have:
(entmake (append (list '(0 . "LINE")
  (assoc 8 data))
  (if (assoc 62 data) (list(assoc 62 data)))
  (if (assoc 6 data) (list(assoc 6 data)))
  (list '(100 . "AcDbLine")
  (cons 10 (tran 10))
  (cons 11 (tran 11))
because the append wipes the nils in my list.
but I would still like to know how to pass BYLAYER to entmake.
thanks.
Never express yourself more clearly than you are able to think.
gile
  • Marseille, France
Re: pass BYLAYER to entmake
« Reply #1 on: August 20, 2009, 11:35:10 AM »
Try :
(cond ((assoc 62 data)) (T '(62 . 256)))
and
(cond ((assoc 6 data)) (T '(6 . "BYLAYER")))
« Reply #2 on: August 20, 2009, 11:43:47 AM »
Like Gile said.
 (assoc 8 data))
 (if (assoc 62 data) (assoc 62 data) '(62 . 256))
 (if (assoc 6 data) (assoc 6 data) '(6 . "BYLAYER"))
 (cons 10 (tran 10))
 (cons 11 (tran 11))
curmudgeon
« Reply #3 on: August 20, 2009, 12:47:16 PM »
Try :
and
just almost....
this works. even better, I can see why it works now.
apologies, Charles. I did not read the code you posted before I started playing with it.
here, an IF is just as good as a COND, and probably reads easier.
  (assoc 8 data)
  (cond ((assoc 62 data)(assoc 62 data))
(T '(62 . 256)))
  (cond ((assoc 6 data)(assoc 6 data))
  '(100 . "AcDbLine")
  (cons 10 (tran 10))
  (cons 11 (tran 11))
very many thanks.
« Last Edit: August 20, 2009, 12:52:00 PM by curmudgeon »
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #4 on: August 20, 2009, 01:16:14 PM »
Try :
and
Good code!
My cent: minus one letter...
(cond((assoc 62 data))('(62 . 256)))
(cond((assoc 6 data))('(6 . "BYLAYER")))
gile
  • Marseille, France
« Reply #5 on: August 20, 2009, 01:23:00 PM »
Or:
(cond((assoc 62 data)) ((cons 62 256)))
(cond((assoc 6 data)) ((cons 6 "BYLAYER")))
