Author Topic: A Bat file question  (Read 1226 times)
GDF
A Bat file question
« on: July 21, 2016, 03:16:48 PM »
Is it possible to edit this bat file to list only the directory folders, in lieu of the dwg files?
DIR *.DWG/B/S > "C:\Arch_Custom\Support\DWG_Full_Path_List.txt"
NOTEPAD "C:\Arch_Custom\Support\DWG_Full_Path_List.txt"
GDF
Re: A Bat file question
« Reply #1 on: July 21, 2016, 03:23:23 PM »
I got this to work
dir /a:d /s /b | sort > "C:\Arch_Custom\Support\DWG_Full_Path_List.txt"
« Reply #2 on: July 21, 2016, 03:23:32 PM »
maybe
dir /a:d
http://ss64.com/nt/dir.html
nevermind you got it but link has info if any else needs it.
« Reply #3 on: July 21, 2016, 03:37:35 PM »
Looks like you can sort the list with the /o:n switch too.
DIR [drive:][path][filename] [/A[[:]attributes]] [/B] [/C] [/D] [/L] [/N]
  [/O[[:]sortorder]] [/P] [/Q] [/R] [/S] [/T[[:]timefield]] [/W] [/X] [/4]
              Specifies drive, directory, and/or files to list.
  /A          Displays files with specified attributes.
  attributes   D  Directories                R  Read-only files
               H  Hidden files               A  Files ready for archiving
               S  System files               I  Not content indexed files
               L  Reparse Points             -  Prefix meaning not
  /B          Uses bare format (no heading information or summary).
  /C          Display the thousand separator in file sizes.  This is the
              default.  Use /-C to disable display of separator.
  /D          Same as wide but files are list sorted by column.
  /L          Uses lowercase.
  /N          New long list format where filenames are on the far right.
  /O          List by files in sorted order.
  sortorder    N  By name (alphabetic)       S  By size (smallest first)
               E  By extension (alphabetic)  D  By date/time (oldest first)
               G  Group directories first    -  Prefix to reverse order
  /P          Pauses after each screenful of information.
  /Q          Display the owner of the file.
  /R          Display alternate data streams of the file.
  /S          Displays files in specified directory and all subdirectories.
  /T          Controls which time field displayed or used for sorting
  timefield   C  Creation
              A  Last Access
              W  Last Written
  /W          Uses wide list format.
  /X          This displays the short names generated for non-8dot3 file
              names.  The format is that of /N with the short name inserted
              before the long name. If no short name is present, blanks are
              displayed in its place.
  /4          Displays four-digit years
GDF
« Reply #4 on: July 21, 2016, 03:44:39 PM »
Is there a way to modify the bat file to only get the [number] named folders?
What I get now:
F:\Service\160136
F:\Service\160136\160107
What I want:
\160136
\160136\160107
