Author Topic: Paper Space Outline Gone  (Read 2598 times)
Rob...
« on: October 26, 2015, 01:36:07 PM »
Just made the switch to 2016 from 2014.
The paper outline in layouts has gone from some files. That's right, some, not all. They were there in all files in the previous version. Nothing has changed except for the switch to 2016. I don't see anything new in page set-ups.
Is this some sort of new "feature"?
CAD Tech
Matt__W
  • I like my water diluted.
Re: Paper Space Outline Gone
« Reply #1 on: October 26, 2015, 02:05:18 PM »
Have you checked the display options?
Autodesk Expert Elite
Rob...
« Reply #2 on: October 26, 2015, 02:07:41 PM »
I did. I have it set so that it displays printable area but not the paper background. The way I've had it for years. What gets me is that only certain files are not showing the paper outline.
CAD Tech
Matt__W
« Reply #3 on: October 26, 2015, 02:21:28 PM »
Just so I'm clear... it's not the viewport that's missing, correct? Can you post a screenshot?
Rob...
« Reply #4 on: October 26, 2015, 02:27:38 PM »
I am talking about the dotted line that represents the edge of the paper.
These are taken from different files within the same session of AutoCAD.
The outline in the 2nd shot should be at the tic mark in the upper left.
CAD Tech
Matt__W
« Reply #5 on: October 26, 2015, 02:35:19 PM »
Do you have DISPLAY PRINTABLE AREA toggled off?? That toggle controls the display of the dashed line.
Rob...
« Reply #6 on: October 26, 2015, 02:40:11 PM »
It is on.
That setting is a system setting and affects all files.
Attached is a file that doesn't show the outline.
CAD Tech
Matt__W
« Reply #7 on: October 26, 2015, 02:43:22 PM »
All of the printer/ctb settings are set and applied to this view? Because after I click APPLY TO LAYOUT and cancel out of the plot dialog box the dashed lines show up.
Rob...
« Reply #8 on: October 26, 2015, 02:48:58 PM »
They are applied. The button is grayed out when I open plot dialog. I change, apply, and cancel and still no joy.
CAD Tech
Matt__W
« Reply #9 on: October 26, 2015, 02:52:02 PM »
Matt__W
« Reply #10 on: October 26, 2015, 02:53:27 PM »
Since I don't have your plotter/printer I can't verify the settings but this seems to be the most likely culprit. The 0 margins is a recurring theme in my Googly search.
https://forums.autodesk.com/t5/autocad-architecture-general/printable-area-in-layout/td-p/2955048
Rob...
« Reply #11 on: October 26, 2015, 03:01:22 PM »
Thanks for that bit-o'-info.
CAD Tech
Rob...
« Reply #12 on: October 26, 2015, 03:15:50 PM »
Dam those new "features"!
CAD Tech
