Author Topic: Feature Line Poly to 3D Poly?  (Read 4985 times)
MSTG007
« on: August 02, 2016, 10:51:29 AM »
Anyone have a good routine that can take a feature line with arcs and explode them to a 3D Polyline "Where the arcs are not segmented lines to make up the arc?"
Civil3D 2020
rkmcswain
Re: Feature Line Poly to 3D Poly?
« Reply #1 on: August 02, 2016, 12:27:09 PM »
What should happen to the Fline arc segments then?
MSTG007
« Reply #2 on: August 02, 2016, 12:32:08 PM »
Well, I did some research.. Apparently I did not have the most recent Service Pack installed. I have it installed now and the issue went away.
https://knowledge.autodesk.com/support/autocad-civil-3d/troubleshooting/caas/sfdcarticles/sfdcarticles/Civil-3D-2016-SP-2-Feature-Line-errors-and-issues.html?_ga=1.122185739.1063247484.1468940069
The reason I was asking for this was once I audited and fixed my errors I would loose certain "insert elevation points".
I knew I could explode the feature line and recreate the line, but with the arcs. They became segmented.
Civil3D 2020
« Reply #3 on: August 02, 2016, 12:38:17 PM »
an export to autocad would get your geometry, but not the elevations back
MSTG007
« Reply #4 on: August 02, 2016, 12:40:44 PM »
Your right about the export, but again it would be nice if it was possible to have 3d arcs with elevations.
Civil3D 2020
« Reply #5 on: August 02, 2016, 02:33:40 PM »
There is so much that would be NICE if autodesk fixed inside C3D, where does one start or end that list?
rkmcswain
« Reply #6 on: August 02, 2016, 03:47:09 PM »
Quote from: mjfarrell
I'd just like them to start by fixing all of the known bugs issues, some of which go back years.
« Reply #7 on: August 02, 2016, 03:55:41 PM »
That makes thousands of us wishing the same thing....however that wont happen as long as autodesk has everyone's' subscription dollars.
« Reply #8 on: August 02, 2016, 06:02:02 PM »
x 1.#INF
