Author Topic: help, problem with coordinates  (Read 1117 times)
TopoWAR
« on: July 22, 2016, 02:08:18 PM »
hello, here asking for your help again, I have a problem, I attached the test.dwg file, autocad tells me that the curve has Z: 3.00, but when using the getpoint command lisp tells me Z: -1.1302, as I do for Z: 3.00 using the command getpoint ??? Thank you for your help!!!!
Thanks for help
Cathy
Re: help, problem with coordinates
« Reply #1 on: July 22, 2016, 02:24:17 PM »
It looks to me like the first vertex has a Z value of 3, but all of the other vertices have a Z value of -1.1302.
TopoWAR
« Reply #2 on: July 22, 2016, 02:27:28 PM »
Cathy , You're right, I had noticed, THANK YOU !!! :-)
Thanks for help
