Author Topic: Directional Drilling  (Read 2697 times)
BlackBox
« on: May 18, 2016, 02:48:34 PM »
What are the limitations on entry, and exit angles for directional drills?
Not so much a Civil 3D related question, as I already use Profiles drawn using Tangents and Curves to represent my directional drills. I'm posting this here, as I was hoping to get some good ole' fashioned design expertise! Haha
Here in Florida, it's been my experience working as a designer, and field inspector for lengthy drilling projects, that directionally drilled/bored HDPE connects to a PVC main via 11.25 degree bend (along with reducer, megalugs, etc. as needed).
My Engineer for this project insists that I specify 45 degree bends - I just cannot see a drilling machine elevate, and maintain that angle for the entirety of a +/-1,000 FT drill, let alone elevating the pipe at the other end in order to even pull it back through - if your experience is different, or you have documentation that would educate me otherwise, please let me know?
Cheers
nobody
  • .net stuff
Re: Directional Drilling
« Reply #1 on: May 18, 2016, 06:52:29 PM »
my solution to situations like this...if he's signing...relax, and don't care muahahahahha
« Reply #2 on: May 19, 2016, 08:33:09 AM »
http://rebar.ecn.purdue.edu/Trenchless/secondpage/Content/HDD.htm
Key Data:
The pilot hole is drilled with a surface-launched rig with an inclined carriage, typically adjusted at an angle of 8 to 18 degrees with the ground for entrance and 8 to 12 degrees for exit angle
« Last Edit: May 19, 2016, 04:00:52 PM by mjfarrell »
sybold
« Reply #3 on: May 21, 2016, 03:10:05 PM »
the pilot pipes is the limit of the radius, if the pipe being installed is pe or pvc, with a steel pipe the installed pipe may be the limiting factor for the radius of the drilling curve.
entry/exit angles is determined by the limits of the drill-rig.
45 degree is possible, but only with a special rig setup. the pilot is not much of a problem. the pull-in operation will be a bigger challenge.
for some more information you can visit this http://www.vshanabdrilling.com , or ask ;)
« Last Edit: May 21, 2016, 03:17:24 PM by sybold »
nobody
  • .net stuff
« Reply #4 on: May 21, 2016, 08:26:47 PM »
Alternately maybe open pit the final 45-degree connections...would mean you'd have to pull back the rig a considerable distance though....guessing there's no room...never is room :/  This would be a case where'd I definitely ask my "engineer" to get a contractor who does the crap involved.
