Author Topic: ==={ Challenge }=== General dyadic operation  (Read 8850 times)
ribarm
  • Marko Ribar, architect
Re: ==={ Challenge }=== General dyadic operation
« Reply #15 on: March 17, 2014, 06:59:13 PM »
(defun dyadic ( f l1 l2 / loop )
  (defun loop ( x y )
      ( (or (null x) (null y)) nil)
      ( (and (atom x) (atom y)) (f x y))
      ( (and (listp x) (listp y)) (mapcar '(lambda ( a b ) (loop a b)) x y))
  (mapcar '(lambda ( a b ) (loop a b)) l1 l2)
Command: (dyadic + '((1 2) 3 (4 5)) '((1 2) 3 (4 5)))
((2 4) 6 (8 10))
Command: (dyadic + '((1 2 3) 3 (4 5)) '((1 2) 3 (4 5)))
((2 4) 6 (8 10))
Command: (dyadic + '(1 3 (4 5)) '((1 2) 3 (4 5)))
(nil 6 (8 10))
(defun mapTree ( f l / k args nullargs atomargs listpargs loop )
  (setq k 0)
  (setq args (mapcar '(lambda ( x ) (read (strcat "arg" (itoa (setq k (1+ k)))))) l))
  (setq k 0)
  (setq nullargs (mapcar '(lambda ( x ) (read (strcat "(null arg" (itoa (setq k (1+ k))) ")"))) l))
  (setq k 0)
  (setq atomargs (mapcar '(lambda ( x ) (read (strcat "(atom arg" (itoa (setq k (1+ k))) ")"))) l))
  (setq k 0)
  (setq listpargs (mapcar '(lambda ( x ) (read (strcat "(listp arg" (itoa (setq k (1+ k))) ")"))) l))
  (eval
    (list 'defun 'loop args
      (list 'cond
        (list (cons 'or nullargs) nil)
        (list (cons 'and atomargs) (cons 'f args))
        (list (cons 'and listpargs) (cons 'mapcar (cons (list 'function (list 'lambda args (cons 'loop args))) args)))
  (apply 'loop l)
Command: (maptree + '(((1 2) 3 (4 5)) ((1 2) 3 (4 5)) ((1 2) 3 (4 5))))
((3 6) 9 (12 15))
Regards, M.R.
« Last Edit: March 18, 2014, 03:35:35 AM by ribarm »
M.R. on Youtube
bruno_vdh
« Reply #16 on: March 18, 2014, 04:06:38 AM »
Hello,
For a journey across the width, it is possible to simplify and remove the anonymous function
(defun dyadic (f l1 l2 / loop)
  (defun loop (x y)
    (cond ((or (null x) (null y)) nil)
          ((or (atom x) (atom y)) (f x y))
          ((mapcar 'loop x y))
  (loop  l1 l2)
_$ (dyadic + '((1 2) 3 (4 5)) '((1 2) 3 (4 5)))
((2 4) 6 (8 10))
Regards,
« Last Edit: March 18, 2014, 04:27:09 AM by bruno_vdh »
irneb
« Reply #17 on: March 18, 2014, 05:00:21 AM »
Another version, which allows for things like (* scalar vector):
  1. (defun dyadic (func a b / do-dyadic do-dyadic-al do-dyadic-la)
  2.   (if (= (type func) 'SYM) (setq func (eval func)))
  3.   (defun do-dyadic (a b)
  4.     (cond ((atom a)
  5.            (cond ((atom b) (func a b))
  6.                  (t (mapcar 'do-dyadic-al b))))
  7.           ((atom b) (mapcar 'do-dyadic-la a))
  8.           (t (mapcar 'do-dyadic a b))))
  9.   (defun do-dyadic-al (b) (do-dyadic a b))
  10.   (defun do-dyadic-la (a) (do-dyadic a b))
  11.   (do-dyadic a b))
Though it does so even within lists, e.g.
_$ (dyadic + '(1 2 4 5 (6 (7))) '(2 3 (4 5) 6 (7 (8))))
(3 5 (8 9) 11 (13 (15)))
Not too sure if that's a "good" thing.  :roll:
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #18 on: March 18, 2014, 10:17:40 AM »
my variant 1:
  1. (defun eea-map1 (a b)
  2.   (cond ((listp a) (mapcar (function eea-map1) a b))
  3.         (+ a b)
  4.   )
  5. )
bruno_vdh
« Reply #19 on: March 18, 2014, 11:10:33 AM »
A shorter version with mapcar, but less good as mapcar does not return an error if arguments asymmetric..
(defun dyadic (f a b / loop)
  (defun loop (x y) (if (atom x) (f x y) (mapcar 'loop x y)))
  (setq f (eval f))
  (loop a b)
((2 4) 6 (8 10))
« Reply #20 on: March 18, 2014, 01:17:36 PM »
@bruno, how about simply:
(defun dyadic ( f a b )
    (mapcar '(lambda ( x y ) (if (atom x) (f x y) (dyadic f x y))) a b)
((2 4) 6 (8 10))
ribarm
« Reply #21 on: March 18, 2014, 01:27:10 PM »
Lee, it's better to use tail recursion than mapcar... My codes also fail in dotted pair cases... Test it and you'll see :
Command: (dyadic + '((1 2) (3 . 4) 5) '((1 2) (3 . 4) 5))
; error: bad list: 4
Bruno's and Gilles's codes firstly posted are better...
M.R. on Youtube
« Reply #22 on: March 18, 2014, 03:52:57 PM »
I know - mapcar cannot process dotted pairs.
bruno_vdh
« Reply #23 on: March 18, 2014, 06:07:58 PM »
@Lee, is a writing is prettier, the choice of the name lambda (loop= lambda) is explained by the factorization (eval f) for more flexibility:
_$ (eval +)
#<SUBR @0000000031458ba8 +>
_$ (eval '+)
bruno_vdh
« Reply #24 on: March 19, 2014, 06:28:23 AM »
Hello,
I take this opportunity to remind a small grammar point to the flexibility of the syntax ((eval f) x y) is not the best, it excludes the use of special forms.
Finally, I think this  (eval (cons f '(x y))), (eval (list f x y))  or this (apply f '(x y)) is preferable ..
To summarize:
(defun dyadic (f a b)
    (mapcar '(lambda ( x y ) (if (atom x) (eval (cons f '(x y))) (dyadic f x y))) a b)
My preference is the latter
(defun dyadic (fun x y)
  (cond ((null (or x y)) nil)
        ((or (atom x) (atom y)) (eval (cons fun '(x y))))
        ((cons (dyadic fun (car x) (car y)) (dyadic fun (cdr x) (cdr y))))
Examples
((2 4) 6 (8 10))
_$ (dyadic 'and '((nil T) T (T T)) '((nil nil) T (nil T)))
Regards,
« Last Edit: March 19, 2014, 07:03:00 AM by bruno_vdh »
ribarm
« Reply #25 on: March 19, 2014, 09:12:56 AM »
Bruno, I've modified your mapTree for symbols and operands...
(defun mapTree (f l)
  (cond ((apply 'or (mapcar 'null l)) nil)
        ((apply 'and (mapcar 'atom l)) (if (eq (type f) 'SYM) (apply f l) (apply 'f l)))
        ((cons (mapTree f (mapcar 'car l)) (mapTree f (mapcar 'cdr l))))
Command: (maptree + '(((1 2) (3 . 4) 5) ((1 2) (3 . 4) 5) ((1 2) (3 . 4) 5)))
((3 6) (9 . 12) 15)
Command: (maptree '+ '(((1 2) (3 . 4) 5) ((1 2) (3 . 4) 5) ((1 2) (3 . 4) 5)))
((3 6) (9 . 12) 15)
M.R. on Youtube
irneb
« Reply #26 on: March 19, 2014, 09:50:44 AM »
Just a question: Does the function always take 2 atomic values as argument? I.e. it never expects a list?
Still not answered. Similar to the dotted pair problem, this makes the generalized function very different. E.g. what if you're using a function like distance to obtain the distances between 2 lists of points?
Same type of thing applies for the dotted pair. Should such even be allowed? I mean, this is a form of mapcar, and since mapcar doesn't allow dotted pairs, should this allow it?
As for recursion (or even tail-call) over mapcar, that is a bit dangerous to use as iteration loop over the list. I think it should be fine to use recursion to iterate over the tree's depth, but it's length might become too long for AutoLisp's stack (i.e. around 15000 iterations).
bruno_vdh
« Reply #27 on: March 19, 2014, 10:11:58 AM »
@ribarm thank you, it was also possible to do like this  :wink::
  (cond ((null (apply 'or l)) nil)
        ((apply 'or (mapcar 'atom l)) (eval (cons f l)))
_$ (maptree 'and '(((1 2) (3 . 4) 5) ((1 2) (3 . 4) 5) ((1 2) (3 . 4) 5)))
((T T) (T . T) T)
_$ (maptree + '(((1 2) (3 . 4) 5) ((1 2) (3 . 4) 5) ((1 2) (3 . 4) 5)))
((3 6) (9 . 12) 15)
ribarm
« Reply #28 on: March 19, 2014, 10:39:03 AM »
Bruno, it was also possible to do it like this :
(defun dyadic (f x y)
        ((and (atom x) (atom y)) (if (eq (type f) 'SYM) (apply f (list x y)) (f x y)))
        ((cons (dyadic f (car x) (car y)) (dyadic f (cdr x) (cdr y))))
((2 4) (6 . 8) 10)
Command: (dyadic '+ '((1 2) (3 . 4) 5) '((1 2) (3 . 4) 5))
((2 4) (6 . 8) 10)
M.R. on Youtube
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #29 on: March 19, 2014, 11:05:02 AM »
((2 4) (6 . 8) 10)
((2 4) (6 . 8) 10)
maybe:
  1. (defun dyadic (f x y)
  2.   (cond ((or (null x) (null y)) nil)
  3.         ((atom x) ((eval f)  x y))
  4.         ((cons (dyadic f (car x) (car y)) (dyadic f (cdr x) (cdr y))))
  5.   )
  6. )
