thanks
Hi
Maybe an alternative as you've access to AutoCAD 2005....
Below snippet comes via a CAD E-mail Newsletter that arrives in my Inbox -
<snip>
In a similar vein, you can make an arc dimension similar to a standard associative dimension. Type Ddunits and set your units as appropriate. At the Command prompt, type Field. Select Object and set your desired units. At the bottom of the Field dialog box, highlight the code, right-click, and select Copy. Cancel the Field command. Start the Dimangular command and select the arc, then T for text paste, and proceed with the command. You end up with an associative dimension for the arc. When you stretch it and regenerate, the field displays the new dimension.
</snip>
Check out # 58 "Arc Dim. R2005" at
http://home.pacifier.com/~nemi/Have a good one, Mike
