Thank you for saving the day! lol. It works just like it needs to to switch the selected profile view style!
This sounds alittle crazy, but I am trying to see if i can create a toggle with this. Basically, I want to select the profile view I want to work in, then do some hatching commands, by picking areas, Then once I am done, change the profile view style back to the original.
So to get this to somewhat work, I came up with something like this..
(defun C:Test ()
(C:test1) ;;Select the profile view to change the style without the grid
(command" "-layer" "OFF" "C-STRC-LABL,C-PIPE-LABL,C-PROF-LABL" "")
(command "-bhatch" "p" "ansi31" "30" "0" pause "")
(command" "-layer" "ON" "C-STRC-LABL,C-PIPE-LABL,C-PROF-LABL" "")
(C:test2) ;;Select the profile view to change the style back to the grid
(princ))
