Author Topic: sort string based on particular order  (Read 3130 times)
David Hall
  • Automatic Duh Generator
« on: May 05, 2006, 06:24:04 PM »
Sorry if this has been done, but I can t find it.
What I'm trying to do is sort a string based on a set order.  What Im doing is sorting lines "text" values for what is in an electrical trench.  the routine grabs all the lines with a crossing window, filtered on layer names, and creates a string of letters based on the layers it found.  Problem is the string is based on the order of creation.  My string letters are P (Primary duct), S (Secondary), L (lighting circuit), and X for CATV.  A typical string might look like PSSXPLPS based on the order of creation.  I am trying to sort it to look like PPPSSSLX.  Im trying to use INSTR, MID, LEFT and RIGHT to manipulate my string.
My idea is to use a while statement (or do while) to check if 'P' is INSTR, and use the returned position to feed the MID function to extract the Letter and create a new string that I will append each letter to.  Then use left and right to concatentate the string back together minus the 'P' we just removed.  Then S, L, and X.
David Hall
Re: sort string based on particular order
« Reply #1 on: May 05, 2006, 06:24:24 PM »
Does this sound like it will work or is there a better way?
« Reply #2 on: May 05, 2006, 06:28:26 PM »
Humm....
« Reply #3 on: May 05, 2006, 07:13:38 PM »
Not very elegant, but does what you need...
Function testCmdrDuh(str2test As String) As String
Dim strFinal As String
Dim I As Integer
I = InStr(1, str2test, "P")
Do Until I = 0
    strFinal = strFinal & Mid(str2test, I, 1)
    str2test = Replace(str2test, "P", "", 1, 1)
Loop
I = InStr(1, str2test, "S")
Do Until I = 0
    str2test = Replace(str2test, "S", "", 1, 1)
Loop
I = InStr(1, str2test, "L")
Do Until I = 0
    str2test = Replace(str2test, "L", "", 1, 1)
Loop
I = InStr(1, str2test, "X")
Do Until I = 0
    str2test = Replace(str2test, "X", "", 1, 1)
Loop
testCmdrDuh = strFinal
End Function
« Reply #4 on: May 05, 2006, 08:22:59 PM »
Better yet:
Function testCmdrDuh(str2test As String, strPattern As String) As String
Dim I As Integer
Dim strPat As String
Do Until strPattern = ""
    strPat = Left(strPattern, 1)
    I = InStr(1, str2test, strPat)
    Do Until I = 0
        str2test = Replace(str2test, strPat, "", 1, 1)
    Loop
    strPattern = Replace(strPattern, strPat, "", 1, 1)
Loop
End Function
Sub test()
Debug.Print testCmdrDuh("PSSXPLPS", "PSLX")
End Sub
Dnereb
« Reply #5 on: May 06, 2006, 06:15:48 AM »
Another way of fixing this problem.
'variation that preserves the rough data in str2test an uses 1 loop only per pattern
'thus speed things up for larger amounts of data.
Function testCmdrDuh(ByVal str2test As String, ByVal strPattern As String) As String
Dim PatternCounter As Long
Dim PatternCharNum As Long
PatternCounter = 1
For PatternCounter = 1 To Len(strPattern)
    strPat = Mid$(strPattern, PatternCounter, 1)
    PatternCharNum = Len(str2test)
    str2test = Replace(str2test, strPat, "")
    strFinal = strFinal & String$(PatternCharNum - Len(str2test), strPat)
Next
End Function
Sub test()
End Sub
David Hall
« Reply #6 on: May 08, 2006, 01:07:26 PM »
thanks guys.  I didn't know about the replace function.  More reading to do.
