Author Topic: wierd line thingy....  (Read 3012 times)
hudster
« on: March 02, 2004, 10:23:02 AM »
I have received an AutoCAD drawing, third hand from my client.
But it has a strange thing going on with some of the lines.
Most of them only have one end point, so when i'm trying to lay out the electrical equipment, i can't select endpoint on about 40% of the lines.
I've asked my client and he can't get another copy of the drawing, so I'll have to use this one.
any ideas what's causing this?
« Reply #1 on: March 02, 2004, 10:34:42 AM »
Are the lines indeed lines or are they rays? A ray only has one endpoint.if it is indeed a line, try listing it and see if it gives you all of the data.
hudster
« Reply #2 on: March 02, 2004, 10:51:55 AM »
It's definitely a line.
Listed one and got this.
Select objects:
                  LINE      Layer: "A_LAYOUT"
                            Space: Model space
                   Handle = 99C0
              from point, X=  8858.57  Y= 69216.39  Z=     0.00
                to point, X=  7733.57  Y= 69216.39  Z=     0.00
          Length =  1125.00,  Angle in XY Plane =    180
                  Delta X = -1125.00, Delta Y =      0.00, Delta Z =     0.00
weird thing is, I redrew some of them, and they still only have one end point, something is screwy with this drawing.
daron
« Reply #3 on: March 02, 2004, 10:59:08 AM »
Try wblocking out just the graphical objects in the drawing. IOW, don't type all to wblock. See if that helps in any way. If you have pspace objects, copy and paste them.
hudster
« Reply #4 on: March 02, 2004, 11:06:48 AM »
Done that, I always wblock all drawings out to a new blank drawing, exploded all entities till all i have is lines, arcs etc then use that drawing as a base for all my layouts.
I've also tried cutting and pasting with this drawing, still no dice.
Audit is returning no errors, and when i click on one of the weird lines, it has the usual 3 grip oints, one at either end, but osnaps just don't seem to work. I can find one endpoint, no middle, other end point, not even nearest works.
Is their perhaps a variable to control the endpoint setting?
« Reply #5 on: March 02, 2004, 11:30:20 AM »
Hudster,
Send me this drawing so I can take a look at it.
Ron
Hangman
« Reply #6 on: March 05, 2004, 12:48:43 PM »
oh, oh, oh, ...
I ran into this problem just a few weeks ago.
They (the guru's here at the swamp) told me that the ...  oh, ...  the, ...  aaaahhhh,  ...  brain cramp, ...  ouch, ...   Hang on, I'll get it ...
Hangman
Found it !!!
« Reply #7 on: March 05, 2004, 12:56:53 PM »
Ok, got it.
It's Whiparc.  You need to set the system variable to tesselate so the circles look like vectors.  Appearantly from Adesk, the whiparc isn't working correctly and at times causes the autosnaps to not function correctly.  At least that was what fixed my problem, ADT 2k4 WXP.   I couldn't get endpoints either.  Hope I helped.   :)
