Author Topic: needing a little tutoring  (Read 2582 times)
amgirard2003
« on: May 05, 2006, 09:10:31 AM »
Good morning all,
I'm currently doing some work that is quite repetitive with 2 commands that is really drivin my crazy having to execute both and would like to combine them together.
here's the code in plain english of how i would like it to work
Prompt user: "Select object to edit"
if object select, varify it has object data before continuing
if object does not have object data
prompt user: "selected object does not have object data"
end command
if object selected has object data
execute ddedit command to modfiy text
once text is modified
execute ADEEDITDATA, modify all the data.
once ok is selected return to original prompt
enter twice to exit command
any help would be greatly appreciated...
I have AIM so send me a pm if you would like to help me out and i'll reply with my AIM username
Andre
Re: needing a little tutoring
« Reply #1 on: May 05, 2006, 09:56:47 AM »
I don't have time this morning but some clarification is needed.
  What action is no object picked, exit?
if object select, verify it has object data before continuing
   Is there a specific block name
   Is there a specific Tag name?
end command
execute ddedit command to modify text
  What is ADEEDITDATA
David Hall
  • Automatic Duh Generator
« Reply #2 on: May 05, 2006, 10:01:10 AM »
I think they are using autocad Map since a reference was made to object data
amgirard2003
« Reply #3 on: May 05, 2006, 10:40:03 AM »
that is correct, using AutoCadMap 2007
« Reply #4 on: May 10, 2006, 10:02:44 AM »
Andre look in your acad installation for <AutoCAD Install>\Help\acmap_dev.chm. You have a choice of  AutoLISP or ActiveX methods. If you still need help please let us know.
