Author Topic: Caps  (Read 2881 times)
Bryco
Caps
« on: April 29, 2006, 04:29:16 PM »
We always use caps in cad so it drives me nuts writing emails etc and finding caps on. I think I have a solution thanks to MP and dubb accidently yelling.
Even though this is virtually a straight copy it took an hour to figure out a way to make it shout when I wanted to. Api's are a bit tricky.
If there is a better way I'm all ears.
Option Explicit
Private WithEvents AutoCAD As AcadApplication
Private Declare Function FindWindow _
    Lib "user32" Alias "FindWindowA" _
    (ByVal lpClassName As String, _
    ByVal lpWindowName As String) As Long
Private Declare Function GetActiveWindow _
    Lib "user32" () As Long
Private Declare Sub keybd_event _
    Lib "user32" _
    (ByVal virtualKeyCode As Byte, _
    ByVal stubbed As Byte, _
    ByVal flags As Long, _
    ByVal pointerToExtraInfo As Long)
Private Declare Function MapVirtualKey _
    Lib "user32" _
    Alias "MapVirtualKeyA" _
    (ByVal virtualKeyCode As Long, _
    ByVal translate As Long) _
    As Long
Private Declare Function GetKeyState _
    Lib "user32" _
    (ByVal virtualKeyCode As Long) _
    As Long
Private Const _
    VKC_CAPSLOCK = &H14, _
    TRANSLATE_TO_SCANCODE = 0, _
    SCANF_KEYUP = &H2, _
    SCANF_KEYEXT = &H1, _
    SCANF_KEYNOTEXT = &H0, _
    NULL_POINTER = 0, _
    SCANF_KEYDOWN = &H28
Public Sub Acadstartup()
  Set AutoCAD = Application
  AutoCAD.WindowState = acMax
  ThisDrawing.WindowState = acMax
Private Sub AutoCAD_AppActivate()
    Dim Shout As Long
    Dim Key As Long
    Key = GetKeyState(VKC_CAPSLOCK)
    If GetActiveWindow = FindWindow("wndclass_desked_gsk", vbNullString) Then
        If Key = 1 Then
            Shout = SCANF_KEYEXT Or SCANF_KEYNOTEXT
        End If
    Else
        If Key = 0 Then
            Shout = SCANF_KEYDOWN
        End If
    End If
    If Shout Then ToggleShout (Shout)
Private Sub AutoCAD_AppDeactivate()
    If GetKeyState(VKC_CAPSLOCK) = 1 Then
        ToggleShout (SCANF_KEYEXT)
    End If
Sub ToggleShout(Shout As Long)
    Call keybd_event( _
        VKC_CAPSLOCK, _
        MapVirtualKey(VKC_CAPSLOCK, TRANSLATE_TO_SCANCODE), _
        Shout Or SCANF_KEYNOTEXT, _
        NULL_POINTER)
    Call keybd_event( _
        VKC_CAPSLOCK, _
        Shout Or SCANF_KEYUP, _
        NULL_POINTER)
Re: Caps
« Reply #1 on: April 29, 2006, 06:05:38 PM »
You might find THIS thread informational/useful
Bryco
Re: Caps
« Reply #2 on: April 30, 2006, 10:52:51 AM »
Good article. Do you need VB to get the download to work?
Re: Caps
« Reply #3 on: April 30, 2006, 02:31:12 PM »
No, but there is a dll mentioned that you must have available.
Bryco
Re: Caps
« Reply #4 on: April 30, 2006, 05:48:12 PM »
All the dll's are in C:\WINNT\system32  but some of them are named in caps if that makes a difference.
Re: Caps
« Reply #5 on: April 30, 2006, 10:00:09 PM »
Caps make no difference .. so long as the files are located in the system folder and are pointed to in the registry ...
