Author Topic: USING POLARMODE  (Read 2757 times)
DEVITG
USING POLARMODE
« on: February 28, 2004, 10:21:16 AM »
the Var
POLARMODE
Controls settings for polar and object snap tracking. The value is the sum of four bitcodes:
Polar angle measurements
0  Measure polar angles based on current UCS (absolute)
1  Measure polar angles from selected objects (relative)
If I set to 1 (relative)
How I can select by LISP, with out the user action, the last line I draw to be the selected object.?? :?:
USING POLARMODE
« Reply #1 on: February 28, 2004, 12:52:50 PM »
(setq ent (entlast))
Returns the name of the last nondeleted main object (entity) in the drawing
The entlast function is frequently used to obtain the name of a new entity that has just been added with the command function. To be selected, the entity need not be on the screen or on a thawed layer.
