Author Topic: Verifying Support Paths before adding or deleting...  (Read 2986 times)
whdjr
« on: April 25, 2006, 10:16:55 AM »
I have been playing around with the support paths through Lisp, adding and deleting paths.  I started out testing to see if the path was already listed in the current path string before adding or deleting any portion of the string.  That part worked fine.  Then I started thinking was there really any need to verify if the chosen path was already included or not so I removed the portion of code to verify the existence of the path and just added or deleted the path I wanted.  I found that if the path was already there AutoCad did not add it again and if the path was not there and you were trying to delete it (via a subst method) you didn't get any errors (which is good).
Has anyone worked with the supprot paths much thru lisp?
Is there really any need to verify the existence of a path before adding or deleting?
Any drawbacks you might know of?
David Hall
  • Automatic Duh Generator
Re: Verifying Support Paths before adding or deleting...
« Reply #1 on: April 25, 2006, 10:21:46 AM »
I did it a little with VBA, but not LISP.  I had a couple of issues, let me see if I can find what I found, it might pertain to lisp also
GDF
« Reply #2 on: April 25, 2006, 11:37:12 AM »
Will
I use the following: <and I do not verify if they exist>
(defun ARCH:FINDACAD#PATH  (/ apath)
  (setq APATH (findfile "acad.exe"))
  (setq ACAD#PATH (substr APATH 1 (- (strlen APATH) 8)))
  (cond ((< (distof (substr (getvar "acadver") 1 4)) 15.0)
         (alert "ARCH Program no longer supports this version of AutoCAD"))
        ((and (>= (distof (substr (getvar "acadver") 1 4)) 15.0)
              (< (distof (substr (getvar "acadver") 1 4)) 16.0))
         (setq ACAD#R_15 (strcat ACAD#PATH "support;" ACAD#PATH "fonts;" ACAD#PATH "help;")))
        ((>= (distof (substr (getvar "acadver") 1 4)) 16.0)
         (setq ACAD#R_16
                (strcat ACAD#PATH "support;" ACAD#PATH "UserDataCache\\Support;" ACAD#PATH
                        "fonts;" ACAD#PATH "help;" ACAD#PATH "support\\color;"))))
  (princ))
(defun ARCH:ACAD_REGISTRY  ()
  (ARCH:FINDACAD#PATH)
         (setenv "ACAD" ACAD#R_15))
         (setenv "ACAD" ACAD#R_16)))
  (princ))
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ARCH Registry ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(defun ARCH:ARCH_REGISTRY  ()
  (ARCH:READKEYS)
  (ARCH:LOADER)
  ;;acaddoc.lsp
         (setq ARCHSTDSETUP
                (strcat "C:\\Arch_Custom\\Support"
                        (substr ARCH#SUPF 1 (- (strlen ARCH#SUPF) 1))
                        (strcat (substr ARCH#SUPF 1 (- (strlen ARCH#SUPF) 1)) "\\V_15")
                        (substr ARCH#FONF 1 (- (strlen ARCH#FONF) 1))
                        (substr ARCH#PATF 1 (- (strlen ARCH#PATF) 1))
                        ACAD#R_15
                        ;;(strcat ARCH#PROF "Exe_ScriptPro")
         (setenv "ACAD" ARCHSTDSETUP))
         (setq ARCHSTDSETUP
                (strcat ;;ACAD#PATH
                        ;;"express;"
                        (strcat (substr ARCH#SUPF 1 (- (strlen ARCH#SUPF) 1)) "\\V_16")
                        ACAD#R_16))
         (setenv "ACAD" ARCHSTDSETUP)))
  (princ))
That way I can setup files specific to AutoCAD's version and user custom files.
Gary
« Last Edit: April 25, 2006, 11:44:14 AM by Gary Fowler »
whdjr
« Reply #3 on: April 25, 2006, 04:39:34 PM »
Thanks for the verification Gary.  :-)
mjguzik
« Reply #4 on: April 25, 2006, 09:33:41 PM »
Here is a little something we use to verify that support paths are present:
;;; Adds specified directory to support path
;;; Example: (addsupppath "C:\\Temp")
;;; Returns: msg
;;; Requires: str->lst function from (toolbox)
(defun addsupppath (dir / prefobj supppath supplst newsupp msg)
  (setq prefobj (vla-get-preferences (vlax-get-acad-object))
supppath (vla-get-SupportPath (vla-get-files prefobj))
supplst (str->lst (strcase supppath) ";")
  (if (not (member (strcase dir) supplst))
    (progn (setq newsupp (strcat supppath ";" dir)
msg (strcat "\n" dir " added to AutoCAD Support Path"))
   (vla-put-SupportPath (vla-get-files prefobj) newsupp)
    (setq msg (strcat "\n" dir " exists within AutoCAD Support Path"))
  (vlax-Release-Object prefobj)
  (if msg (princ msg))
;;; FUNCTION: STR->LST
;;; DESCRIPTION: Converts delimited string to list
;;; ARGS: delimited string
;;; EXAMPLE: (STR->LST "test1,test2,test3,test4" ",")
;;; RETURNS: ("test1" "test2" "test3" "test4")
(defun str->lst (str delim / lst pos)
  (setq pos (vl-string-search delim str))
  (while pos
    (setq lst (cons (substr str 1 pos) lst)
  str (substr str (+ pos 2))
    ) ; end while
  (if (> (strlen str) 0)(setq lst (cons str lst)))
  (reverse lst)
« Reply #5 on: April 25, 2006, 10:17:21 PM »
mjguzik,
Welcome to the swamp and thanks for sharing. :-)
LE
« Reply #6 on: April 25, 2006, 10:49:05 PM »
If I remember [according to the few brain cells left].... is there any limit on the number of paths?
« Reply #7 on: April 25, 2006, 11:17:11 PM »
I have a vague recollection that the total string length can't exceed something just over a thousand characters or so (no, not 2^10) but I could be wrong. Sorry, don't have time to test to find out out, as easy as that would be.
