Author Topic: Vertical TextStyle Function  (Read 3646 times)
LE
« on: April 24, 2006, 11:33:20 PM »
Here is a function to change the vertical property for a textstyle.
static int ads_verticaltextstyle(void) {
struct resbuf *pArgs = acedGetArgs();
char pTextName [256];
if (pArgs && pArgs->restype == RTSTR) {
strcpy(pTextName, pArgs->resval.rstring);
//acDocManager->lockDocument(acDocManager->curDocument());
AcDbTextStyleTableRecordPointer pTextStyle(pTextName,acdbCurDwg(),AcDb::kForWrite);
Acad::ErrorStatus es = pTextStyle.openStatus();
if ((es == Acad::eOk) && !pTextStyle->isVertical()) {
//pTextStyle->upgradeOpen();
pTextStyle->setIsVertical(Adesk::kTrue);
acedRetT();
} else {
acedRetNil();
return (RSRSLT);
LE
Re: Vertical TextStyle Function
« Reply #1 on: April 25, 2006, 12:06:44 AM »
Here another version [have not tested myself]
Now, it will include a new argument to turn on and off the Isvertical property [but wait for the masters].
Acad::ErrorStatus es;
short flag;
if (pArgs && pArgs->restype == RTSTR && pArgs->rbnext && pArgs->rbnext->restype == RTSHORT) {
flag = pArgs->resval.rint;
if (flag != 0 || flag != 1) acedRetNil();
if (pTextStyle.openStatus() == Acad::eOk) {
switch(flag) {
case 1:
if (!pTextStyle->isVertical()) {
acedRetT();
} else {
acedRetNil();
break;
case 0:
if (pTextStyle->isVertical()) {
pTextStyle->setIsVertical(Adesk::kFalse);
acedRetT();
} else {
acedRetNil();
break;
return (RSRSLT);
Alexander Rivilis
  • Programmer from Kyiv (Ukraine)
« Reply #2 on: April 25, 2006, 07:51:11 AM »
First of all change:
flag = pArgs->resval.rint;with:
flag = pArgs->rbnext->resval.rint;Also it will be useful return 0 or 1 dependency on pTextStyle->isVertical() and nil if parameters are wrong or another error in function:
acedRetNil(); // In begining of function;
acedRetInt(pTextStyle->isVertical()); // In end of function
LE
« Reply #3 on: April 25, 2006, 08:57:28 AM »
Oops...
I'm about to check the function right now, I wrote the code late last night [blind].
Thanks.
LE
« Reply #4 on: April 25, 2006, 09:32:29 AM »
Here is the updated function:
short flag;
if (flag == 0 || flag == 1) {
switch(flag) {
case 1:
break;
case 0:
break;
else { acedRetNil(); }
return(RSRSLT);
« Last Edit: April 26, 2006, 10:41:36 AM by LE »
