Author Topic: Testing a string for a number  (Read 6878 times)
whdjr
« on: April 24, 2006, 11:56:31 AM »
What would be a good and easy/quick way to test a string to see if it is a number?
(atoi "aaa")   ==> 0
(atoi "0")      ==> 0
(atoi "111")  ==> 111
Any ideas?
Re: Testing a string for a number
« Reply #1 on: April 24, 2006, 12:09:20 PM »
How about
(numberp (read (substr str 1 1)))or
(numberp (read str))
Alexander Rivilis
  • Programmer from Kyiv (Ukraine)
« Reply #2 on: April 24, 2006, 12:11:18 PM »
(distof "aaa")  ==> nil
(distof "0") ==> 0.0
(distof "111") ==> 111.0
« Reply #3 on: April 24, 2006, 12:13:26 PM »
I think this might work.  Written on the fly.
(defun IsStrNums (String)
 (mapcar
  '(lambda (x) (>= 48 x 57))
  (vl-string->list String)
I think that is the right function to use (vl-string->list), but not sure.
Edit:  Change the test to greater than or equal, not less than or equal.
« Last Edit: April 24, 2006, 12:25:46 PM by T.Willey »
« Reply #4 on: April 24, 2006, 12:16:57 PM »
That's a nice one Rivilis. :-)
(distof "2'-3 1/2\"")
27.5
« Reply #5 on: April 24, 2006, 12:21:48 PM »
Oho, potential fun: I think if i remeber correctly numbers take up codes 48 and up in ascii codes. ... 0 = 48 1 = 49...
Alexander Rivilis
« Reply #6 on: April 24, 2006, 12:33:34 PM »
27.5
On my AutoCAD: (distof "2'-3 1/2\"") ==> nil because LUNITS is setting to 2
This function is dependent on LUNITS variable. If you need test only decimal number (not architectural, nor engineering)
you must use (distof val 2)  - val is a testing string.
« Reply #7 on: April 24, 2006, 01:23:11 PM »
Perhaps this may be useful --
(defun MyDistOf ( string / result )
    (vl-some
       '(lambda (mode)
            (setq result
                (distof
                    string
                    mode
       '(2 3 5 4 1)
    result
From here.
whdjr
« Reply #8 on: April 24, 2006, 01:24:07 PM »
Thanks for the reply guys those are some great examples but I think for simplicity sake I will use the method suggested by CAB.
How about
Thanks again guys,
« Reply #9 on: April 24, 2006, 01:33:12 PM »
I don't know the context you're going to use it Will but do be careful --
    Command: (numberp (read "123 abc")) => T
    Command: (numberp (mydistof "123 abc")) => nil
Should your host application consider "123 abc" a number?
whdjr
« Reply #10 on: April 24, 2006, 01:41:36 PM »
Thanks Michael,
The list will either be a number or a string not both so I think the numberp will work fine.  Thanks for your code though it definitely covers all the bases.  :-)
whdjr
« Reply #11 on: April 24, 2006, 01:51:12 PM »
Michael,
Upon further trials:
    Command: (numberp (read "123 abc")) => T -> In the VLIDE it strips everything off after the space.
    Command: (numberp (read "123abc")) => Nil  If you remove the space then it nil's out.
Just FYI.
« Reply #12 on: April 24, 2006, 01:58:25 PM »
Precisely why I posted that example Will.
An aside, here's another variant I wrote that is relatively bomb proof --
(defun distanceof ( x  / result )
   (vl-catch-all-apply
      '(lambda ()
           (vl-some
              '(lambda (units) (setq result (distof x units)))
               (list (getvar "lunits") 4 5 2 1)
   result
From here.
whdjr
« Reply #13 on: April 24, 2006, 02:04:39 PM »
Thanks Michael,
I like that one a little better because once it catches a T it stops processing.  Very COOL.
Thanks,
« Reply #14 on: April 24, 2006, 02:33:39 PM »
Thanks Michael..
Here is something to consider, although may not be relevant to Will.
Command: test1                             Command: test2
*--> 3.5        gives number: 3.5          *--> 3.5        gives number: 3.5
" type: " 2
*--> 3 1/2      gives number: 3.5          *--> 3 1/2      gives number: 3.5
" type: " 2
*--> 3 1/2"     gives number: 3.5          *--> 3 1/2"     gives number: 3.5
" type: " 3
*--> 3 1/2'     gives number: 42.0         *--> 3 1/2'     gives number: 42.0
" type: " 3
*--> 3-1/2'     gives number: 42.0         *--> 3-1/2'     gives number: 42.0
" type: " 3
*--> 3'-1"      gives number: 37.0         *--> 3'-1"      gives number: 37.0
" type: " 3
*--> 3' -1"      gives number: 3             **  Invalid Number  **  3' -1"
" type: " 6
*--> 3'- 1"      gives number: 3             **  Invalid Number  **  3'- 1"
" type: " 6
*--> 3'-1       gives number: 37.0         *--> 3'-1       gives number: 37.0
" type: " 3
*--> 3' 1       gives number: 37.0         *--> 3' 1       gives number: 37.0
" type: " 3
*--> 3' 1"      gives number: 37.0         *--> 3' 1"      gives number: 37.0
" type: " 3
*--> 3' 1 1/2   gives number: 37.5         *--> 3' 1 1/2   gives number: 37.5
" type: " 3
*--> 3'-1-1/2   gives number: 37.5         *--> 3'-1-1/2   gives number: 37.5
" type: " 3
*--> 3' 1 1/2"  gives number: 37.5         *--> 3' 1 1/2"  gives number: 37.5
" type: " 3
*--> 3' 1.5     gives number: 37.5         *--> 3' 1.5     gives number: 37.5
" type: " 3
*--> 3' .5      gives number: 36.5         *--> 3' .5      gives number: 36.5
" type: " 3
*--> 3'.5      gives number: 36.5          *--> 3'.5      gives number: 36.5
" type: " 3
  **  Invalid Number  **  10-1               **  Invalid Number  **  10-1
*--> -10        gives number: -10.0        *--> -10        gives number: -10.0
" type: " 2
  **  Invalid Number  **  -10-1              **  Invalid Number  **  -10-1
*--> .5         gives number: 0.5          *--> .5         gives number: 0.5
" type: " 2
*--> 0.5        gives number: 0.5          *--> 0.5        gives number: 0.5
" type: " 2
*--> 5 -2       gives number: 5              **  Invalid Number  **  5 -2
" type: " 6
*--> 1/2        gives number: 0.5          *--> 1/2        gives number: 0.5
" type: " 2
*--> 1/2"       gives number: 0.5          *--> 1/2"       gives number: 0.5
" type: " 3
*--> 9 1/2      gives number: 9.5          *--> 9 1/2      gives number: 9.5
" type: " 2
*--> 1.55E+01   gives number: 15.5         *--> 1.55E+01   gives number: 15.5
" type: " 2
  **  Invalid Number  **  5A                 **  Invalid Number  **  5A
*--> 5 A        gives number: 5              **  Invalid Number  **  5 A
" type: " 6
(defun c:test1 (/ txt txtlst num)
  (setq txtlst
         (list  "3.5       "   ; type:  2
                "3 1/2     "   ; type:  2 ?5
                "3 1/2\"    "  ; type:  4
                "3 1/2'    "   ; type:  4
                "3-1/2'    "   ; type:  4
                "3'-1\"     "  ; type:  4
                "3' -1\"     " ; Invalid Number
                "3'- 1\"     " ; Invalid Number
                "3'-1      "   ; type:  4
                "3' 1      "   ; type:  4
                "3' 1\"     "  ; type:  4
                "3' 1 1/2  "   ; type:  4
                "3'-1-1/2  "   ; type:  4
                "3' 1 1/2\" "  ; type:  4
                "3' 1.5    "   ; type:  4
                "3' .5     "   ; Invalid Number
                "3'.5     "    ; type   3
                "10-1      "   ; Invalid Number
                "-10       "   ; type:  2
                "-10-1     "   ; Invalid Number
                ".5        "   ; type:  2
                "0.5       "   ; type:  2
                "5 -2      "   ; type:  6
                "1/2       "   ; type:  2 ?5
                "1/2\"      "  ; type:  4
                "9 1/2     "   ; type:  2 ?5
                "1.55E+01  "   ; type:  2
                "5A        "   ; Invalid Number
                "5 A       "   ; type:  6
  (setq idx -1)
  ;;  distof will tollerate trailing spaces but not any other character
  ;;  therefore READ can be used to extract numbers followed by characters IF
  ;;  there is a space behing the number (read "12 A") = 12 (read "12a") = "12a"
  (while (< (setq idx (1+ idx)) (length txtlst))
    (setq txt (nth idx txtlst))
    ;;  must be tested in this order (2 1 5 4 3)
    ;; if you use (1 2 3 4 5) you will not get any 2 4 or 5 results
    ;;  further test result in inconsistancies with 3&4 and 5 types
    (cond ((setq num (distof txt 2))
           (setq typ 2)
          ((setq num (distof txt 1))
           (setq typ 1)
          ((setq num (distof txt 5))
           (setq typ 5)
          ((setq num (distof txt 3))
           (setq typ 3)
          ((setq num (distof txt 4))
           (setq typ 4)
          ((setq num (read txt))
           (setq typ 6)
          ); get number if followed by a space "10 a" = 10
           ;; (read "10a") = "10a" so you must test result with
           ;;   (numberp "10a") results in 'not a number'
    (if (numberp num) ;  Got a valid number
        (prompt (strcat "\n*--> " txt " gives number: "))
        (princ num)
        (print " type: ")
        (princ typ)
      (prompt (strcat "\n  **  Invalid Number  **  " txt))
test2
    (setq num (distanceof txt))
        (princ num)
        (print)
