Hey all, could you enlighten me with an idea of how to select a text previously created.
Here's the issue.
(setq pt1 (getpoint "\nSelect Corner or Edge of Entity: "))
(setq ang1 (getangle pt1 "\nSelect angle or Return for 45: "))
(if (= ang1 nil)
(setq ang1 (/ pi 4))
);end if
(setq ang2 (cvunit ang1 "radian" "degree"))
(command "dtext" pt1 ang2 pause)
So, after the dtext has been written. Be it two, three, or four lines or more, is it possible to assign each line of text to a variable without physically selecting each line ? And if so, how can this be done ?
Thank you.
