Author Topic: xdata retrieval... what's wrong  (Read 1692 times)
uncoolperson
« on: April 21, 2006, 04:36:41 PM »
I'm trying this out for the first time... errrr, can't figure out why it seems like it's putting the data with the ent... but then it's not there
(DEFUN setframe (text frame)
  (if (not (tblsearch "APPID" "FRAMEFUN"))
  (regapp "FRAMEFUN")
  (REGAPP "FRAMEFUN")
  (SETQ text-ent (ENTGET text))
  (SETQ data (LIST
(LIST -3
       (LIST "FRAMEFUN"
     (CONS 1005 (CDR (ASSOC 5 (ENTGET frame))))
  (IF (= (ASSOC -3 text-ent) nil)
    (SETQ new-ent (APPEND text-ent data))
    (SETQ new-ent (SUBST (ASSOC -3 text-ent) data text-ent))
  (ENTMOD new-ent)
(DEFUN getframe (text)
  (SETQ data (CDR (CADR (CADR (ASSOC -3 (ENTGET text))))))
  (HANDENT data)
« Last Edit: April 21, 2006, 05:12:22 PM by CAB »
Re: xdata vanmilla lisp like... what's wrong
« Reply #1 on: April 21, 2006, 05:01:20 PM »
Try this:
  (SETQ data (CDR (CADR (CADR (ASSOC -3 (ENTGET text'("FRAMEFUN")))))))
  (HANDENT data)
« Reply #2 on: April 21, 2006, 05:02:27 PM »
Ok, if i can see the spelling mistakes in your thread title, you know its really screwed up.
uncoolperson
« Reply #3 on: April 21, 2006, 05:05:50 PM »
hey vanmilla is fun...
thanks CAB... you know it points that out in the help file, and I... I , i guess i just skipped that part.
Thank agian
