Author Topic: Taxi! please....  (Read 3490 times)
Water Bear
Taxi! please....
« on: February 26, 2004, 11:26:31 AM »
I made some changes, added a loop at the end but it won't work..can you tell me why?
(defun duct_calc
       (/ friction volume velocity diam width depth area_sqft)
;;;                      Local Functions
  ;;  returns the square side dimension equivelant of rnd duct
  (defun rnd_to_sqr (dia ; dia of round duct
    a ; side A of square duct
    / loop fuzz b)
    (if (= (type a) 'int) ; make sure A is a REAL
      (setq a (* a 1.0))
    (setq b    a ; B is target
 fuzz 0.001
 loop t
    ;;  Returns Side B of square duct
    (while loop
      (setq dia2
    (* 1.3
(exp (/ (log (/ (expt (* a b) 5) (expt (+ a b) 2))) 8))
      (if (equal dia2 dia fuzz)
(setq loop nil) ; done
(setq b (* b (/ dia dia2)))
    b
    ) ; end defun
  ;;  given the area in square feet returns the diameter
  (defun area2dia (sf_area / square)
    (setq square (sqrt (* sf_area 144.0)))
    (* 1.3
       (exp
(/ (log (/ (expt (* square square) 5.0)
   (expt (+ square square) 2.0)
   8.0
    ) ; end defun
  ;;  given diameter returns the side dimension
  (defun dia2sq (dia)
    ;;(* dia 0.914774703)
    ;;(*(sqrt area_sqft)12)
    (setq depth (* (sqrt area_sqft) 12)) ; CAB
    (rnd_to_sqr dia depth) ; CAB
  ;; given the diameter returns the area in sq ft
  (defun dia2area (dia)
    ;;(/ (* 0.7854 (expt dia 2.0)) 144.0)
    (/ (* pi (expt (/ dia 2.0) 2.0)) 144.0) ; CAB
  ;;given a square duct, make it round<=====added this
  (defun make_round (w d)
    (* 1.3
       (exp
(/ (log (/ (expt (* w d) 5.0)
   (expt (+ w d) 2.0)
   8.0
  (defun veloc2press (vel)
    (expt (/ vel 4005.00) 2)
  ;;  calc friction
  (defun find_fric ()
    (/ (* 0.109136 (expt volume 1.9)) (expt diam 5.02))
  ;;print results
  (defun show_me ()
    (textscr)
    (mapcar '(lambda (x)
      (prompt (strcat "\n"
      (car x)
      (if (cdr x)
(rtos (cdr x) 2 2)
"X"
   (list (cons "Diameter " diam)
 (cons "Width    " width)
 (cons "Depth    " depth)
 (cons "Volume   " volume)
 (cons "Velocity " velocity)
 (cons "Friction " friction)
;;;                    Start of Routine
  ;;                    Get User Input
  (prompt "\nEnter known values. Press Enter if not known. ")
  (setq diam (getreal "\nEnter duct diameter: "))
  (if (null diam) ; skip if diameter entered
    (setq width (getreal "\nEnter duct width: ")
 depth (getreal "\nEnter duct depth: ")
  (setq volume (getreal "\nEnter total CFM'S: ")
loop   t
  (if (null (and (or diam (and width depth)) volume))
    (setq friction (getreal "\nEnter FRICTION value: "))
    (setq velocity (getreal "\nEnter Velocity in FPM: "))
  ;;                Process User Input
    ((and friction diam)
     (setq volume    (exp
      (/ (log (/ (* friction (expt diam 5.02)) 0.109136))
 1.9
  area_sqft (dia2area diam)
  width     (dia2sq diam)
  velocity  (/ volume area_sqft)
    ((and friction volume)
     (setq diam     (exp
      (/ (log (/ (* 0.109136 (expt volume 1.9)) friction))
 5.02
  width     (dia2sq diam)
    ((and diam volume)
     (setq area_sqft (dia2area diam)
  width     (dia2sq diam)
  friction  (find_fric)
    ((and diam velocity)
  width     (dia2sq diam)
  volume    (* area_sqft velocity)
    ((and width depth friction)
     (setq diam    (make_round width depth)
  volume   (exp
1.9
  velocity (/ volume (dia2area diam))
    ((and width depth volume)
    ((and width depth velocity)
  volume   (* (dia2area diam) velocity)
    ((and volume velocity)
     (setq area_sqft (/ (/ volume velocity) 0.914774703)
  diam     (area2dia area_sqft)
  width     (dia2sq diam)
    (t
       ((or volume velocity)
(prompt
 "\nYou must enter diameter or Width x Depth ..."
       (t
(prompt "\nYou must indicate CFMs or FPM..")
    ) ; end cond stmt
  (show_me)
;friction ; return flag, nil if failed
  (while loop
    (setq width (getreal "\nEnter new duct width: ") ;WB
 depth (getreal "\nEnter new duct depth: ")
    (if (or width depth)
((= width t)
(setq depth (rnd_to_sqr diam width)
(show_me)
((= depth t)
(setq width (rnd_to_sqr diam depth)
(show_me)
    (setq loop nil)
    ) ;end while
  ) ; end defun
(defun c:test (/ friction)
  (while (setq friction (duct_calc)))
  (print friction)
Taxi! please....
« Reply #1 on: February 26, 2004, 12:41:44 PM »
Without post the entire code again, here's the bottom of it.
(prompt
       (t
    )               ; end cond stmt
  (show_me)
  ;; added this ---------------------------------
  (setq ask (getint "\nRun this again? (1=Yes <No>): "))
  (if ask (duct_calc))
  ;; remove from here down ----------------------
;;;  (while (setq width (getreal "\nEnter new duct width: ")) ;WB
;;;     (setq depth   (getreal "\nEnter new duct depth: ")
;;;    (if (or width depth)
;;;      (cond
;;;   ((= width t)
;;;    (setq depth   (rnd_to_sqr diam width)
;;;          diam   (make_round width depth)
;;;          velocity   (/ volume (dia2area diam))
;;;          friction   (find_fric)
;;;    (show_me)
;;;   ((= depth t)
;;;    (setq width   (rnd_to_sqr diam depth)
;;;    (show_me)
;;;   ; (setq loop nil)
;;;    )               ;end while
  )               ; end defun
Taxi! please....
« Reply #2 on: February 26, 2004, 12:43:39 PM »
Also you might want to add the names of all those nested defun's to the local variable list.
Water Bear
Taxi! please....
« Reply #3 on: February 26, 2004, 01:45:07 PM »
Thanks for the help Mark. But what I am trying to accomplish is that when I input the known variables it  calcs the rest, then based on that, I want to loop thru only width and depth (using the diam, volume, velocity and friction that was gathered) that way I only have to enter eitherwidth or depth not both
(setq A(rnd_to_sqr diam B))if I enter A (since I already know diam), this will calc the other side--then, if I can't use that size, I'll try another..
Taxi! please....
« Reply #4 on: February 26, 2004, 02:07:04 PM »
(defun duct_calc
       (/ friction volume velocity diam width depth area_sqft loop)
;;;                      Local Functions
           / loop fuzz b)
      (setq a (* a 1.0))
     fuzz 0.001
     loop t
    (while loop
      (setq dia2
        (*   1.3
    b
    )               ; end defun
    (* 1.3
       (exp
       8.0
    )               ; end defun
  (defun dia2sq   (dia)
    (* 1.3
       (exp
          (expt (+ w d) 2.0)
       8.0
  ;;  calc friction
  (defun find_fric ()
  ;;print results
  (defun show_me ()
    (textscr)
                (car x)
                (if (cdr x)
             (rtos (cdr x) 2 2)
             "X"
  ;;                    Get User Input
   loop   t
     (setq volume    (exp
           1.9
      width     (dia2sq diam)
     (setq diam        (exp
           5.02
      width     (dia2sq diam)
    ((and diam volume)
      width     (dia2sq diam)
      width     (dia2sq diam)
      volume   (exp
          1.9
      width     (dia2sq diam)
    (t
   (prompt
       (t
    )               ; end cond stmt
  (show_me)
  (setq loop 1)
  (while loop
(cond ((setq width (getreal "\nEnter new duct width: "))
  (show_me)
 ((setq depth (getreal "\nEnter new duct depth: "))
  (show_me)
 (T (setq loop nil))
) ;end while
Water Bear
Taxi! please....
« Reply #5 on: February 26, 2004, 02:25:31 PM »
Sensational!!! I was close..but no cigar...:D
