Author Topic: New drawing without command  (Read 3209 times)
« on: April 20, 2006, 01:50:53 PM »
I have a bunch of batch programs, and then seem to crash at the end, and it seems the reason is because of the new command that is issued.  I have tried to use the Method New for the active document, but I can't seem to get it to work.
Command: (VLAX-INVOKE ACTDOC 'NEW
"C:/ACADSUPP2004/Template/3M-TITLEBLOCK-B.dwt")
***  AAAaaarrrrgghhhh  ***    AutoLISP encountered this error:  AutoCAD:
AutoCAD is unable to service automation request
"C:/ACADSUPP2004/Template/3M-TITLEBLOCK-B.dwg")
Any help is appreciated.  Thanks in advance.
CADmium
Re: New drawing without command
« Reply #1 on: April 20, 2006, 02:28:41 PM »
try this
;;; call     : (DT:DWT-NEW  "C:\\Vorlage.dwt")
(defun DT:DWT-NEW1 (DWTNAME / DWT)
  (and(=(type DWTNAME) 'STR)
      (not(vl-catch-all-error-p
            (setq DWT(vl-catch-all-apply
                       'vla-add
                       (list
                         (vla-get-documents
                           (vlax-get-acad-object)
                         DWTNAME
            (vl-catch-all-apply
              'vla-activate
              (list DWT)
;;; call: (DT:DWT-NEW2 "D:\\mdt2004\\einstellungen\\vorlagen\\ke-tka.dwt")
(defun DT:DWT-NEW2(DWTNAME)
            (vl-catch-all-apply
              'vla-sendcommand
                 (list
                   (vla-get-activedocument
                   (strcat
                     "vbastmt "
                     (strcat"AcadApplication.Documents.Add" (chr 34)DWTNAME(chr 34))
                     (chr 13)
and for a qnew ..
(defun DT:DWT-GET-STANDARD ( / NAME)
  (if (and(setq NAME (vl-registry-read
                       (strcat "HKEY_CURRENT_USER\\"
                               (vlax-product-key)
                               "\\PROFILES\\"
                               (vla-get-ActiveProfile
                                 (vla-get-PROFILES
                                   (vla-get-preferences
                               "\\GENERAL"
                       "QnewTemplate"
          (setq NAME (findfile NAME))
    NAME
(defun c:my-qnew(/ dwtname)
  (if (setq dwtname ( DT:DWT-GET-STANDARD))
    (DT:DWT-NEW2 DWTNAME)
"Bei 99% aller Probleme ist die umfassende Beschreibung des Problems bereits mehr als die Hälfte der Lösung desselben."
« Reply #2 on: April 20, 2006, 02:45:58 PM »
Thanks.  I had to change it a little as I would need this when I'm in sdi mode.  Here is your code with my slight modification.
            (vl-catch-all-apply
              'vla-sendcommand
                 (list
                   (strcat
                     "vbastmt "
                     (strcat"AcadApplication.ActiveDocument.New" (chr 34)DWTNAME(chr 34)) ; TMW
                     (chr 13)
« Reply #3 on: April 21, 2006, 06:33:46 PM »
This doesn't seem to be working.  It looks like it wants to have that as the last statement in the lisp routine, and I need it to be like the third or fourth from the last.  I will continue to look for a way.
Thanks.
« Reply #4 on: April 21, 2006, 06:58:31 PM »
..... and I need it to be like the third or fourth from the last.
Can you expand on this, Tim? Such as: what else needs to run?
You see, the way I see this working is you open/create a new drawing and as soon as the first one closes or the new one becomes the Active drawing then the lisp will stop executing. Lisp can only operate within the scope of the drawing it was initiated in.
« Reply #5 on: April 21, 2006, 07:05:43 PM »
Sure.
This is my batch plot routine.  I change it to SDI mode so that I can run a lisp to plot instead of a script or a VBA program.  It will plot and all, but when it was trying to execute the new command after it finishes plotting all the drawings, it would crash it.  So I tried to code a way to open a new drawing, but that doesn't seem to something that the ActiveX controls support for lisp.  The vbastmt waits until the end of the routine finishes, and then runs the statement, which causes an error because now it's in MDI mode.
Psuedo code:
Change to SDI mode
Select the drawings, and plot options
Plot them all
Open a new drawing
Change all variables back, mainly back to MDI mode if Acad was in it before the plot routine.
I hope that is clear.
