Author Topic: Lisp experation  (Read 6376 times)
Re: Lisp experation
« Reply #15 on: April 20, 2006, 09:28:01 AM »
This may be over the top.
How about writhing to the registry, like this.
When the program starts it looks for a data file and a registry entry.
If not found it ask for the key code with DEMO as a default.
Write the encoded word plus today date and the number of records in a
data file. Assuming your routine adds records to this data file.
Also update a data file with a flag that the countdown has started.
This way if the registry entry has been deleted the data file will alert
the routine of that fact. "Error, Registry damaged" and quit.
If there is a registry record and the data file is missing the routine will not continue.
When the expiration date is reached or the maximum number of new records is
reached the registry is updated with expired flag. Game over.
David Hall
  • Automatic Duh Generator
Re: Lisp experation
« Reply #16 on: April 20, 2006, 11:30:49 AM »
That sounds great, I could use that in some of my programs.  So how would we go about setting that up?
Re: Lisp experation
« Reply #17 on: April 20, 2006, 11:55:09 AM »
OH, I'm just the idea man. 8-)
whdjr
Re: Lisp experation
« Reply #18 on: April 20, 2006, 03:50:50 PM »
Hey...I thought I was the idea man and you were the one to expand the code... :lmao:
Sounds kinda cool CAB!
Re: Lisp experation
« Reply #19 on: April 20, 2006, 05:35:00 PM »
 :evil:
Re: Lisp experation
« Reply #20 on: April 20, 2006, 05:56:02 PM »
The Reg does just fine but a file can be alot easier to use.
LE
Re: Lisp experation
« Reply #21 on: April 20, 2006, 06:57:06 PM »
I have no idea if still is around the control activelock [activex - VB - free], that can be use in visual lisp applications, to generate trial versions of your software.
HTH.
vinnyg
Re: Lisp experation
« Reply #22 on: May 03, 2006, 08:49:51 AM »
Hey, PitchBlack98
You got it to work?  I'm still confused but only because I'm not
experienced enough to figure it out like you. Could you post this routine
with a small lisp included so I can see for myself how it works in
actual practice and maybe learn how to write and merge different codes
by looking at it.
thanks,
vinnyg
SPDCad
Re: Lisp experation
« Reply #23 on: May 03, 2006, 12:26:43 PM »
I use a straight counter. 30 uses of the programme and then the nag message kicks in. After 50 uses the programme stops running.
I have written the trial code for a client of mine who conveniently forgets to pay me, until the programme stops working.
A date clock trial can be easily hacked by reseting the date on your computer.  ;-)
AutoCAD 2010, w/ OpenDCL
visit: http://reachme.at/spd_designs
Crank
Re: Lisp experation
« Reply #24 on: May 06, 2006, 06:18:56 AM »
... unless you create a registry flag and stop working if that flag is present.
Amsterdammed
Re: Lisp experation
« Reply #25 on: May 06, 2006, 09:14:20 PM »
Chrank,
I set an setenv with the first time the code is loading and every time IT runs till the enddate, I if the computertime is earlier than it already was the code also quits.
Bernd
PitchBlack98
Re: Lisp experation
« Reply #26 on: November 20, 2006, 12:49:26 PM »
I wanted to update this thread...
This bit of code doesnt work in AutoCAD 06 or 07 for me. It seems it can't find the date and errors the entire lisp even if it should still run.
