When they start shooting a feature, sat the edge of an asphalt road, they would enter "B EA" in the data collector. When they have shot as far as the can they then would type in "END". They would repeat this for all lineal features. When they pick back up on that last asphalt shot they would enter "B EA" and then "R what ever that last shot number was" ie "R 145" and then start shooting the road again. When they have shot as far as they can again, the type in "END".
If your figure prefix library and DWT file are set up correctly, when you import your FBK file, the lines will be automatically be drawn for you.
You can see the time savings there vs node to node line work. EVERYTHING in about 5 seconds. Really.
Tell you what, go to your setup and see what abbreviations are listed under you Figure Prefix Library and let me know what they are. I think there is a short library pre-loaded with LDD. If so I can send you an FBK file with the codes in it. Some of the linework should come in and give you a general idea of how this works.
Better yet I will see about putting one on the Lily Pond so everybody can play. Just got to find one that I can release. (Oh, the program will give an error something like "Figure not defined yet" , just tell it to IGNORE ALL. We already know it's not defined.
