Author Topic: remove Indention tap stop position from mtext  (Read 3221 times)
Humbertogo
« on: April 18, 2006, 07:30:38 AM »
Is there a way to remove Indention tap stop position from mtext, the indention position is not always the same.
Using vba
for example:
 \pi-0.875,l0.875;1.HALLO TEST
Need to remove \pi-0.875,l0.875;  from the Mtext the indention position is not always the same.
joseguia
Re: remove Indention tap stop position from mtext
« Reply #1 on: April 18, 2006, 09:14:21 AM »
Using vba
for example:
Hmm - not sure but it sounds like you want something like this?
Function FndText(strString As String)
  On Error GoTo Err_Control
  Dim Lng As Integer
  ' Searches string for ";" and returns everything to the Right
  ' If no ";" found returns original string
  Lng = InStr(strString, ";")
    If Lng > 0 Then
      FndText = Right(strString, (Len(strString) - Lng))
    Else
      FndText = strString
    End If
Exit_Here:
  Exit Function
Err_Control:
  Select Case Err.number
  'Add your Case selections here
    Case Else
    MsgBox Err.Description
    Err.Clear
    Resume Exit_Here
  End Select
End Function
sample use:
FndText "\pi-0.875,l0.875;1.HALLO TEST"
returns:
1.HALLO TEST
joseguia
« Reply #2 on: April 18, 2006, 09:15:22 AM »
Something tells me you need more than just that .. right?
Humbertogo
« Reply #3 on: April 18, 2006, 09:40:41 AM »
Thanks ,
i will do some more investigation
Bryco
« Reply #4 on: April 18, 2006, 10:59:18 AM »
What version Acad Humbertogo?
On acad 2006 I get
\pi-0.75,l0.75,t0.75;1. vhkas\P2.   oiibdf\P3.  qwe
I'm thinking the | and the t do some magic to set the tab spacing.
You don't seem to have that part.
I know on 2000 with a funky text like architxt I could never get it nice
but 2006 is always good.
Humbertogo
« Reply #5 on: April 19, 2006, 01:34:06 AM »
We use Autocad Mechanical 2006
