Author Topic: Batch Convert to Mickeystation  (Read 3640 times)
« on: February 25, 2004, 01:53:48 PM »
Hey Se7en (or any other Microstation user),
Is there a way to batch convert AutoCAD files to dgn (v7) by selecting a directory or something?
Thanks,
Ron :D
pmvliet
« Reply #1 on: February 25, 2004, 03:21:11 PM »
yes,
what software tools are at your disposal?
Microstation V8 or any conversion software?
Or are you jsut looking for a one shot deal?
Pieter
« Reply #2 on: February 25, 2004, 03:48:50 PM »
I'm not up-to-date on the issues with all this drawing conversion stuff yet so i say just DXF-out the dwg and open 'er up in Crapystation.
Dent Cermak
« Reply #3 on: February 25, 2004, 04:05:50 PM »
AutoCad dwg files open directly in Anygraph V8. There is a built in conversion routine in prior versions. (or so the troll that uses anygraph here says.) BUT BOTH ARE ONE AT A TIME DEALS.
« Reply #4 on: February 25, 2004, 04:19:22 PM »
Oh sorry, I just re-read your Q. I dont know if any BATCH converters exist. I also looked over at Opendesign aliance and they didnt have anything either.
« Reply #5 on: February 25, 2004, 04:50:40 PM »
I have version 7 and version 8. The files I need to submit need to be in v7 format. What is the quickest way to convert all these files (about 100 of them)?
Thanks,
Ron
Dent Cermak
« Reply #6 on: February 25, 2004, 06:19:57 PM »
very carefully
pmvliet
« Reply #7 on: February 26, 2004, 12:21:46 PM »
in V8,
go to Utilities,
Batch converter.
You want to select your DWG files, tell it you want them to be V7 dgn files.
tell it where to put them.
under edit, you can set certain settings, you can map layering to numbers etc...
You'll have to play with it to get what you want in the end.
Pieter
« Reply #8 on: February 26, 2004, 12:51:22 PM »
thanks Pieter....I'll give it a try.
« Reply #9 on: February 26, 2004, 01:43:01 PM »
Is that batch converter an add-on? I do not see that option under utilities.
pmvliet
« Reply #10 on: February 27, 2004, 12:24:17 PM »
I guess I should clarify,
what version of V8 do you have installed?
I am running 08.01.01.09
this would be V8.1
I would take a guess your still on v8.0 and that must not be in there
or at least not in the same place...
let me know
Pieter
« Reply #11 on: February 27, 2004, 01:32:15 PM »
I'm running 08.00.00.21. Is there a liveupdate or something for this software?
pmvliet
« Reply #12 on: February 27, 2004, 04:12:24 PM »
providing you have "select services" you can go to Bentley's website
and download the new version.
It is a little big but I'm sure you know that already.
peiter
