Author Topic: Block can not be exploded  (Read 4417 times)
ML
« on: April 14, 2006, 03:17:08 PM »
I was wondering if someone can help me.
We have some blocks in work that should not be exploded under any circumstances. I am trying to write some code using the begin command event that will recognize the block if someone tries to explode it and prevent it from being exploded. Any help would be appreciated. Here is what I have so far
Thank you
Dim blkref As AcadBlockReference
On Error Resume Next
For Each blkref In ThisDrawing.ModelSpace
If blkref.Name = ("xarw") Then
If CommandName = ("EXPLODE") Then
MsgBox "This item can not be exploded"
End If
End If
Next
ThisDrawing.SendCommand ("undo") & vbCrLf
End Sub
ElpanovEvgeniy
  • Moscow (Russia)
Re: Block can not be exploded
« Reply #1 on: April 14, 2006, 03:21:44 PM »
Take advantage of block MINSERT
« Reply #2 on: April 14, 2006, 03:26:58 PM »
David Hall
  • Automatic Duh Generator
« Reply #3 on: April 14, 2006, 03:29:17 PM »
maybe use AcadDocument.BeginCommand
Bryco
« Reply #4 on: April 14, 2006, 05:03:55 PM »
Ml, below seems to work. I both love and hate begincommand, the escape sequences are tricky,
 but this doesn't seem to have that problem.
Explode deletes the blockref at some point as shown by
Private Sub AcadDocument_ObjectErased(ByVal ObjectID As Long)
   MsgBox ObjectID
End Sub
So perhaps there is an efficient way to use that useless now defunct objectid
but selectionsets are fast
so below may be your best shot.
Option Explicit
Private Sub AcadDocument_BeginCommand(ByVal CommandName As String)
    Debug.Print CommandName
    If CommandName = "EXPLODE" Then
        Dim SStart As AcadSelectionSet
        Set SStart = sset(2, "xarw", "SStart")
    End If
End Sub
Private Sub AcadDocument_EndCommand(ByVal CommandName As String)
    Dim SEnd As AcadSelectionSet
    Set SEnd = sset(2, "xarw")
    If ThisDrawing.SelectionSets("SStart").Count > SEnd.Count Then
        MsgBox "Behave"
        ThisDrawing.SendCommand "Undo 1 "
    End If
End If
End Sub
Public Function sset(Optional FilterType, Optional FilterData As Variant, Optional ssName As String = "SS") As AcadSelectionSet
    Dim oSSets As AcadSelectionSets
    Set oSSets = ThisDrawing.SelectionSets
    For Each sset In oSSets
        If sset.Name = ssName Then
            sset.Delete
            Exit For
        End If
    Next
    Set sset = ThisDrawing.SelectionSets.Add(ssName)
    If IsMissing(FilterData) Then
        sset.Select 5
        Exit Function
    End If
    Dim FType() As Integer
    Dim FData() As Variant
    Dim I As Integer
    If IsArray(FilterType) = False Then
        If IsArray(FilterData) = False Then
            ReDim FType(0)
            ReDim FData(0)
            FType(0) = FilterType
            FData(0) = FilterData
        Else
            Exit Function
        End If
    Else
        If UBound(FilterType) <> UBound(FilterData) Then
            Exit Function 'They must be pairs
        End If
        ReDim FType(UBound(FilterType))
        ReDim FData(UBound(FilterType))
        For I = 0 To UBound(FilterType)
            FType(I) = FilterType(I)
            FData(I) = FilterData(I)
        Next
    End If
        sset.Select 5, FilterType:=FType, FilterData:=FData
End Function
Sdoman
« Reply #5 on: April 14, 2006, 06:38:38 PM »
Thank you
<clip>
Mark,
What version of AutoCAD are you running?  Beginning with AutoCAD 2005 ( i think ? ), you can make blocks unexplodeable by checkmarking a box inside the block command dialogue.
Probably a way to do the same via code.   But I don't know VBA, and haven't tried with lisp.
« Reply #6 on: April 14, 2006, 07:04:00 PM »
From the Autdesk DevHelp this is a property of the BLOCK object, so setting it to false for this one Block definition should make all insertions of it unexplodable...
Quote from: AcadDevHelp
Explodable Property
Specifies whether the block can be exploded.
Signature
object.Explodable
object
Block
The object or objects this property applies to.
Explodable
Boolean; read-write
TRUE: The block can be exploded.
FALSE: The block cannot be exploded.
Remarks
Note To access this property, use the IAcadBlock3 interface.
Bryco
« Reply #7 on: April 14, 2006, 07:23:23 PM »
Nice work, too easy.
