Author Topic: Overkill by selection (crossing or window)  (Read 3391 times)
TJAM51
« on: April 13, 2006, 09:27:57 AM »
I am using 2006. Is there a routine similar to overkill but will work through a window of crossing selection only.....thanks
Re: Overkill by selection (crossing or window)
« Reply #1 on: April 13, 2006, 09:48:54 AM »
TJAM51
« Reply #2 on: April 13, 2006, 10:31:09 AM »
When I run this routine it does not prompt me to select anything or any areas. It runs on its own without any prompts.
« Reply #3 on: April 13, 2006, 11:15:42 AM »
Yes, that's why I said "You could modify this one".
Is that something you can do?
TJAM51
« Reply #4 on: April 13, 2006, 12:06:37 PM »
I apologize Cab...did not read that portion of your reply... :| I do not have the experience to develope this routine that far.....I do appreciate your assistance
« Reply #5 on: April 13, 2006, 01:56:05 PM »
Find and change this line
        old   (ssget "_X")
to this
        old   (progn (prompt "\nSelect objects or enter ALL.")(ssget))
« Reply #6 on: April 13, 2006, 01:58:09 PM »
By the way I just discovered the source of the code:
;Tip1744:  CLEAR.LSP        Clear duplicates      (c)2001, Andrzej Gumula
TJAM51
« Reply #7 on: April 14, 2006, 11:25:57 AM »
I replaced the line of code as you indicated and I received the following error....
malformed list on input
RbtDanforth
« Reply #8 on: April 14, 2006, 11:49:27 AM »
Before there was overkill I wrote this
(DEFUN C:SLX (/ A  C CN    DEL)  ;B X Y Z  XZ
         (SETQ A (SSGET (LIST(CONS 0 "LINE")))
               C (SSLENGTH A)CN 0 QQ nil  B nil p nil  cnt 0
               B (REPEAT C (SETQ XZ (SSNAME A CN)
                                 CN (1+ CN)
                                 B (IF B (APPEND B (LIST XZ))(LIST XZ))
                  ) ;REPEAT
         ) ;SETQ
         (FOREACH Q B
                      (SETQ X (ENTGET Q)
                            Y (princ(CDR (ASSOC 10 X))  )
                            Z (CDR (ASSOC 11 X))
                            R (COND ((= (CAR Y)(CAR Z))
                               (LIST (CAR Y)(MAX(CADR Y)(CADR Z))(MIN(CADR Y)(CADR Z))))
                               ((= (CADR Y)(CADR Z))
                               (LIST (CADR Y)(MAX(CAR Y)(CAR Z))(MIN(CAR Y)(CAR Z))))
                               (T  (LIST(ANGLE Y Z) Y Z))
                             QQ (IF QQ (APPEND QQ (LIST R))(LIST R))
         (FOREACH Q B
                      (SETQ X (ENTGET Q)
                            Y (CDR (ASSOC 10 X))
                               (T  (LIST Y Z))
                            r2 (cadr r) R3 (caddr r)
                              PL (PRINC R)
                              pl (princ(length (member (assoc (car r) QQ)QQ)))
                            ZZ(PROMPT "\n")
                            p (IF p
                                  (cond ((MEMBER R p) (PROGN (ENTDEL Q)(setq cnt(1+ cnt))  (princ p)))
                                        ((> pl 0)(if (stest QQ r)(progn (entdel q)(setq cnt(1+ cnt)))(princ p) ))
                                        (t   (CONS  R p))
                                  (LIST R))
         )(princ cnt)(princ "removed") (TERPRI)
(defun stest ( qq r / sa sb ss sx sy )
           (setq sa (car r)
                 sb (assoc sa qq)
                 ss (member sb qq)
                 sx (cadr sb)sy (caddr sb)
  (while (and (null stp) ss)
           (setq stp (or (> sy r2 r3)(< sx r3 r2))
                 sb (assoc sa (cdr ss))
                 ss (member sb ss)
                 sc (length ss)
(princ stp) )
It only does lines on top of other lines and is not idiot proof, but you can select what you want to do.
as an equal problem of cleaning up other peoples work I wrote this to clean up all those exploded hatch 0-Length  lines that often arrive on my desk.  :pissed:  I'm not sure what overkill does with them.
(DEFUN C:SLN (/ A B C CN X Y Z DEL)
               C (SSLENGTH A)CN 0
               B (REPEAT C (SETQ X (SSNAME A CN)
                                 CN (1+ CN)
                                 B (IF B (APPEND B (LIST X))(LIST X))
                  ) ;REPEAT
         ) ;SETQ
         (FOREACH Q B
                      (SETQ X (ENTGET Q)
                            DEL (IF (EQUAL 0 (DISTANCE Y Z) 0.0001) (ENTDEL Q))
TJAM51
« Reply #9 on: April 14, 2006, 11:56:04 AM »
Thanks for all your assistance, but it appears that there are still lines or whatever still left. For example I placed 5 lines on top of one another and when I ran the routine it deleted one leaving 4 behind.
« Reply #10 on: April 14, 2006, 01:27:46 PM »
tj,
Did you get the Clear.lsp to work?
Ans did it remove the excess lines?
TJAM51
« Reply #11 on: April 14, 2006, 04:36:02 PM »
The clear lisp would not work by crossing or window selection...it would run through the entire drawing.....
