Author Topic: ThisDrawing.Utility.GetPoint  (Read 4927 times)
Humbertogo
« on: April 13, 2006, 09:05:29 AM »
I have a  problem using the function ThisDrawing.Utility.GetPoint in VBA (Autocad Mechanical 2006)
i Pick to point but sometimes the second point nothing nd don't go to the Error treatment routine.
don't give me a err.
Murphy
Re: ThisDrawing.Utility.GetPoint
« Reply #1 on: April 13, 2006, 09:25:31 AM »
Please post your code here so we can figure out where it is breaking.
Bryco
« Reply #2 on: April 13, 2006, 09:56:53 AM »
I posted a getpointex function in the downloads (Needs to be moved in first) that may help.
Humbertogo
« Reply #3 on: April 13, 2006, 11:08:30 AM »
Thanks for GetPointex
the mouse button was the problem
Bryco
« Reply #4 on: April 13, 2006, 09:22:23 PM »
I'm glad it helped. I posted it this morning but it's still not there?
nivuahc
« Reply #5 on: April 13, 2006, 09:35:54 PM »
Lines and Points
It was approved, but you submitted it to "General". I moved it to "Lines and Points" under the VBA section. If there's a different section you feel it should be in, let me know and I'll take care of that for ya. :)
Bryco
« Reply #6 on: April 13, 2006, 10:00:26 PM »
Thanks nivuahc,it's in the right spot. I was wondering if Humbertogo  had downloaded it but somehow I couldn't find it or what.
nivuahc
« Reply #7 on: April 13, 2006, 10:45:48 PM »
My pleasure :)
You'd posted it twice, it seems, and each one had been downloaded. One of them 2 times, the other 5. Either way, it looks like Humbertogo found it :)
