Author Topic: Mechanical help...  (Read 10644 times)
Water Bear
Mechanical help...
« on: February 24, 2004, 03:24:18 PM »
Thanks to the good folks here at The Swamp I've worked up this duct calculator which makes conversions based on volume (cfm), velocity (fpm) and conversts to and from round ducts...it still needs some work to make it "pretty" but I've gone about as far as I know how...anyway I'll post it for input (I couldn't get it to calculate friction loss/100' duct) if anyone has suggestions please post, and if you can use it you're welcome to...thanx
(defun duct_calc (/)
;;;          volume  pressure   velocity
;;;  diam     rey_no fric_fac   width
;;;  depth     square friction   area_sqft
  (setq diam (getreal "\nEnter duct diameter:")
width (getreal "\nEnter duct width:")
depth (getreal "\nEnter duct depth:")
volume (getreal "\nEnter total CFM'S:")
velocity (getreal "\nEnter Velocity in FPM:")
    ((and diam volume)
     (setq area_sqft (/ (* 0.7854 (expt diam 2.0)) 144.0)
  width     (* diam 0.914774703)
  depth     (* diam 0.914774703)
  velocity  (/ volume area_sqft)
  pressure  (expt (/ velocity 4005.00) 2)
     (find_fric)
    ((and diam velocity)
  volume    (* area_sqft velocity)
     (find_fric)
    ((and width depth volume)
     (setq area_sqft (* (/ (* width depth) 144.0) 0.914774703)
  square    (sqrt (* area_sqft 144.0))
  diam     (* 1.3
(exp
 (/ (log (/ (expt (* square square) 5.0)
    (expt (+ square square) 2.0)
    8.0
     (find_fric)
    ((and width depth velocity)
  diam     (* 1.3
(exp
    8.0
     (find_fric)
    ((and volume velocity)
     (setq area_sqft (/ (/ volume velocity) 0.914774703)
  diam     (* 1.3
(exp
    8.0
     (find_fric)
   (t
((if volume
  t
(prompt
  "\nYou must enter diameter or Width x Depth or FPM..."
((if velocity
  t
(prompt
  "\nYou must enter a diameter or Width x Depth or CFM..."
(t
(prompt "\nYou must indicate CFMs or FPM..")
(defun find_fric ()
  (setq rey_no (* 0.075 diam velocity (/ 1.0 0.0432))
;<=need coefficient for viscosity of standard air in pounds/ft hr
fric_fac (/ 64.0 rey_no) ;<=only good if reynolds is less than 2000
friction (* fric_fac (/ 1200 diam) pressure)
) ;<==Darcy/Weisbach
:D
Mechanical help...
« Reply #1 on: February 24, 2004, 03:28:43 PM »
Cool. (I work in the mech field too.) Ill help help as much as i can when i get spare time. (I work in Microstation alot now, but i do still use Acad once and a while so this would be cool.)
Mechanical help...
« Reply #2 on: February 24, 2004, 05:07:00 PM »
Excellent job there water bear
Water Bear
Mechanical help...
« Reply #3 on: February 24, 2004, 05:17:47 PM »
Thanks for the kind words Mark. I, in turn, must thank CAB, and DParcon for their help... :D
SMadsen
Mechanical help...
« Reply #4 on: February 24, 2004, 05:37:30 PM »
Looks really great, Water Bear.
The factor 0.914774703, is that a workaround for not isolating one of the square sides in the formula that was discussed in the "you say you're pretty good at numbers...." thread?
Man, I gave up on that formula.
Water Bear
Mechanical help...
« Reply #5 on: February 24, 2004, 05:42:43 PM »
Yes, SMadsen, that's the one that had me pulling my hair out! lol
Mechanical help...
« Reply #6 on: February 24, 2004, 06:53:00 PM »
Great job...
Some superficial stuff that is a personal preference.
You can create local functions to make the code more readable
and it localizes formula. So if you need to change a formula
it is in one place not many copies.
I added some window dressing and did a little filter on the inputs.
I'm still on the lower end of programing prowess so consider the
source.
;;; Duct calc returns the friction value
;;;                      Local Functions
  ;;  given the area in square feet returns the diameter
  (defun area2dia (sf_area / square)
    (setq square (sqrt (* sf_area 144.0)))
    (* 1.3
       (exp
            8.0
  ) ; end defun
  ;;  given diameter returns the side dimension
  (defun dia2sq (dia)
    (* dia 0.914774703)
  ;;  given the diameter returns the area in sq ft
  (defun dia2area (dia)
    (/ (* 0.7854 (expt dia 2.0)) 144.0)
  ;;  given the sides returns the area in sq ft
  (defun rec2area (w d) ; retangle to area
    (* (/ (* w d) 144.0) 0.914774703)
  (defun veloc2press (vel)
    (expt (/ vel 4005.00) 2)
  ;;  calc friction
  (defun find_fric ()
;;;                    Start of Routine
  (prompt "\nEnter known values. Press Enter if not known. ")
  (setq diam (getreal "\nEnter duct diameter: "))
  (if (null diam) ; skip if diameter entered
    (setq width (getreal "\nEnter duct width: ")
          depth (getreal "\nEnter duct depth: ")
  (setq volume   (getreal "\nEnter total CFM'S: ")
        velocity (getreal "\nEnter Velocity in FPM: ")
  ;;                  Process user input
    ((and diam volume)
     (setq area_sqft (dia2area diam)
           width     (dia2sq diam)
           depth     width
           pressure  (veloc2press velocity)
     (find_fric)
           width     (dia2sq diam)
           depth     width
     (find_fric)
     (setq area_sqft (rec2area width depth)
           diam      (area2dia area_sqft)
     (find_fric)
     (find_fric)
           width     (dia2sq diam)
           depth     width
     (find_fric)
    (t (alert "\nInsufficient data retry inputs..."))
  ) ; end cond stmt
) ; end defun
Water Bear
Mechanical help...
« Reply #7 on: February 24, 2004, 07:26:42 PM »
Nice mop-up! Looks much cleaner! what do you think about a prompt for additional info, I had added this
(t
   ((if volume
      t
    (prompt
   ((if velocity
      t
    (prompt
   (t
instead of that last condition? and can we get it to switch to (textscr) and list all variables..
Mechanical help...
« Reply #8 on: February 24, 2004, 07:52:45 PM »
How about this?
   (t
       ((or volume velocity)
        (prompt
       (t
(defun c:test (/ friction)
  (while (null (setq friction (duct_calc))))
  (print friction)
Water Bear
Mechanical help...
« Reply #9 on: February 24, 2004, 08:43:08 PM »
Looks really good CAB putting it all together...how about  something like this at the end:
;;;                      Local Functions
    (* 1.3
       (exp
   8.0
    ) ; end defun
  (defun dia2sq (dia)
    (* dia 0.914774703)
  ;;  calc friction
  (defun find_fric ()
  ;;               Process character pressed
    ((and diam volume)
  width     (dia2sq diam)
  depth     width
     (find_fric)
  width     (dia2sq diam)
  depth     width
     (find_fric)
     (find_fric)
     (find_fric)
  width     (dia2sq diam)
  depth     width
     (find_fric)
    (t
(prompt
 "\nYou must enter diameter or Width x Depth..."
       (t
    ) ; end cond stmt
  (textscr)
  (mapcar 'print
 (list diam volume width depth velocity friction)
Mechanical help...
« Reply #10 on: February 24, 2004, 10:27:52 PM »
Ok, add some more input filter and revised you print function.
(defun duct_calc (/          friction   volume     pressure
                  velocity   diam       rey_no     fric_fac
                  width      depth      area_sqft
;;;                      Local Functions
    (* 1.3
       (exp
            8.0
  ) ; end defun
  (defun dia2sq (dia)
    (* dia 0.914774703)
  ;;  calc friction
  (defun find_fric ()
  ;;                    Get User Input
  (setq volume (getreal "\nEnter total CFM'S: "))
  (if (null (and (or diam (and width depth)) volume))
    (setq velocity (getreal "\nEnter Velocity in FPM: "))
  ;;                Process User Input
    ((and diam volume)
           width     (dia2sq diam)
           depth     width
     (find_fric)
           width     (dia2sq diam)
           depth     width
     (find_fric)
     (find_fric)
     (find_fric)
           width     (dia2sq diam)
           depth     width
     (find_fric)
    (t
        (prompt
       (t
  ) ; end cond stmt
  (textscr)
  (mapcar '(lambda (x) (prompt (strcat "\n" (car x) (rtos (cdr x) 2))))
          (list (cons "Diameter " diam)
                (cons "Width    " width)
                (cons "Depth    " depth)
                (cons "Volume   " volume)
                (cons "Velocity " velocity)
                (cons "Friction " friction)
) ; end defun
  (print friction)
Water Bear
Mechanical help...
« Reply #11 on: February 24, 2004, 10:47:57 PM »
Man! you aregood! And you've only been doing this for 3 months? :shock:
Now if I could only figure out the @#$% friction factor! The problem there is that  they use Colebrook's equation which "...cannot be explictly solved for the friction factor, so you must use iterative techniques. :twisted:
Mechanical help...
« Reply #12 on: February 24, 2004, 11:02:15 PM »
Thanks.
No, more like a year. 8)
Gettin started is the hard part.
Water Bear
Mechanical help...
« Reply #13 on: February 24, 2004, 11:16:59 PM »
CAB, take a look at this one and give me your thoughts:
This is supposed to replace the formula I have for "fric_fac"
Mechanical help...
« Reply #14 on: February 24, 2004, 11:32:52 PM »
That math is over my head :(
Is that the formula they talk about here?
Note: Friction losses have been calculated based on the Darcy equation.
The friction factor was determined by using a simplified formula by
Altshule/Tsal (see ASHRAE, 1997 Fundamentals, Chapter 32). The absolute
roughness factor of 0.0003 ft for the medium smooth roughness category
galvanized steel ductwork is used in the calculation.
One another subject,
Have you run across any software you would recommend for calculating and print a
Manual J form. Hillsborough County requires it for permit & although I use the
Energy Gauge software it doesn't print the Manual J.
