Author Topic: block insertion trouble  (Read 2788 times)
NWcivil77
« on: April 13, 2006, 12:13:19 AM »
Hello,
I have the attached snippet in a block insertion routine, and one of the things I can't figure out is how to insert a block into model space from an active viewport in paperspace.  Currently if you are in paperspace with an active model space viewport it will insert the block somewhere off in paperspace.  Could someone steer me in a new direction with this?  Thanks...
If VAR = 1 Then
Set blkObj = ThisDrawing.ModelSpace.InsertBlock(PNT, blkname, ScaleVal, ScaleVal, ScaleVal, ANG)
Else
Set blkObj = ThisDrawing.PaperSpace.InsertBlock(PNT, blkname, ScaleVal, ScaleVal, ScaleVal, ANG)
End If
Bryco
Re: block insertion trouble
« Reply #1 on: April 13, 2006, 12:57:09 AM »
Not enough info but I'm backing your var is lying.
Put the following in thisdrawing
'Thank  Glenn R
Public Property Get CurrentSpace() As AcadBlock
  If Me.GetVariable("CVPORT") = 1 Then
    Set CurrentSpace = Me.PaperSpace
  Else
    Set CurrentSpace = Me.ModelSpace
  End If
End Property
Set blkObj = ThisDrawing.CurrentSpace.InsertBlock(PNT, blkname, ScaleVal, ScaleVal, ScaleVal, ANG)
NWcivil77
« Reply #2 on: April 13, 2006, 01:26:35 AM »
Thanks for the reply and please forgive my novice ability, here is the total code for my module, I am having trouble applying the code posted previously...
Option Explicit
Global layobj As AcadLayer
Global layername As String
Global layercolor As OLE_COLOR
Dim clayer As AcadLayer
Global blkname As String
Dim ANGVARNAME As String
Dim ANG As String
Dim sysvarname As String
Dim VAR As String
Dim ScaleVal As String
Dim PNT As Variant
Dim blkObj As AcadBlockReference
Public Static Property Get CurrentSpace() As AcadBlock
  Else
  End If
End Property
Public Static Function blockin()
On Error Resume Next
 Set clayer = ActiveDocument.ActiveLayer
   Set layobj = ThisDrawing.Layers.Item(layername)
            If Err <> 0 Then
                Set layobj = ThisDrawing.Layers.Add(layername)
                layobj.Color = layercolor
            End If
            ActiveDocument.ActiveLayer = layobj
ANGVARNAME = "SNAPANG"
ANG = ThisDrawing.GetVariable(ANGVARNAME)
sysvarname = "tilemode"
VAR = ThisDrawing.GetVariable(sysvarname)
If blks.fullscale.Value = True Then ScaleVal = 1
If blks.tenscale.Value = True Then ScaleVal = 10
If blks.twentyscale.Value = True Then ScaleVal = 20
If blks.thirtyscale.Value = True Then ScaleVal = 30
If blks.fortyscale.Value = True Then ScaleVal = 40
If blks.fiftyscale.Value = True Then ScaleVal = 50
If blks.sixtyscale.Value = True Then ScaleVal = 60
If blks.onexxscale.Value = True Then ScaleVal = 100
'Get the points from the user
 PNT = ThisDrawing.Utility.GetPoint _
                (, vbCrLf & "Insertion point: ")
'If VAR = 1 Then
'Set blkObj = ThisDrawing.ModelSpace.InsertBlock(PNT, blkname, ScaleVal, ScaleVal, ScaleVal, ANG)
'Else
'Set blkObj = ThisDrawing.PaperSpace.InsertBlock(PNT, blkname, ScaleVal, ScaleVal, ScaleVal, ANG)
'End If
ActiveDocument.ActiveLayer = clayer
Set layobj = Nothing
Set clayer = Nothing
Set PNT = Nothing
Set blkObj = Nothing
End Function
Bryco
« Reply #3 on: April 13, 2006, 01:45:01 AM »
No worries.
"Me" can only be used in the thisdrawing module or forms.  So if you place the function in a standard module replace the me with thisdrawing.
  If ThisDrawing.GetVariable("CVPORT") = 1 Then
    Set CurrentSpace = ThisDrawing.PaperSpace
  Else
    Set CurrentSpace = ThisDrawing.ModelSpace
  End If
End Function
It looks like you are using it right.
Comment out that on error next to find out.
            If Err <> 0 Then
            End If
Not needed, replace with
 Set layobj = ThisDrawing.Layers.Add(layername)  (This never errors for layers whereas an existing block would)
NWcivil77
« Reply #4 on: April 13, 2006, 03:28:41 PM »
Excellent!!  That works perfectly.  Thank you very much!!!
