Just in case anyone was doing a plotting routine, and you want to select the paper from a list that you make. I had to add an bit of coding to get the usual names shown in the plot dialog. The original list would return a list of "User123" type paper names. Once I got that list, I processed it this way to get want is shown in Acad's plot dialog.
(vlax-invoke Lo 'GetLocaleMediaName x)
Here is the complete function that I use with help from Alan.
(defun GetPaperNames (Lo PlotterFile)
(vlax-invoke Lo 'RefreshPlotDeviceInfo) ; CAB
(if (/= (strcase PlotterFile) (strcase (vla-get-ConfigName Lo)))
(vla-put-ConfigName Lo PlotterFile)
(mapcar '(lambda (x) (vlax-invoke Lo 'GetLocaleMediaName x)) (vlax-invoke Lo 'GetCanonicalMediaNames))
