Author Topic: Why is this action_tile crashing??  (Read 3235 times)
Krushert
  • FREE BEER Tomorrow!!
« on: April 10, 2006, 09:38:15 PM »
Need a little help in debugging this.
Why is this action_tile crashing??  It creates the WBlock file in the correct location.  And that is where it stops, right at the end of Action tile “rb1” line.  I took out line of code for “rb2” and it is still crashing at “rb1” line. Animate and Stop @ break confirmed the same thing.
    (unload_dialog dcl_id) ;unload
  ;; Main Application ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
(today)
(StrPath)
(vl-mkdir NewPath)
(setvar "expert" 4)
(action_tile "rb1" "(command " Wblock " NewFile " * ")")
;New version 2004 file with date Prefix
(action_tile "rb2" "(command " saveas " " 2000 " OldFile)")
  ;New version 2000 file with date Prefix
(command "saveas" "2004" OldFile) ;Saves back to the Orginal File.
(setvar "expert" 0)
(setq *error* old_error)
);;End of Routine
When I check it with the editor’s check, I get this warning.
[CHECKING TEXT Tedstest.LSP loading...]
; warning: too many arguments: (ACTION_TILE "rb1" "(command " WBLOCK ... )
; Check done.
Question so I can understand this.  Is the “action_tile” function nothing more that a fancy “IF” function?
Re: Why is this action_tile crashing??
« Reply #1 on: April 10, 2006, 09:57:58 PM »
you cannot use "command" as the action of any action_tile. If you wish to use COMMAND as the result of any button the user may press, I would suggest that what you do is:
Remove COMMAND from the function call in the action_tile
Set a variable (call it whatever you like)
dismiss the dialog box
execute COMMAND based on the value of the variable you set ...
It could be done as such:
(action_tile "rb1" "(setq which_action 1)")
(action_tile "rb2" "(setq which_action 2)")
;;; extraneous code here
(done_dialog);how you achieve it is entirely up to you
(setvar "expert" 4)
 ((= which_action 1)(vl-cmdf " Wblock " NewFile " * "))
 ((= which_action 2)(vl-cmdf " saveas " " 2000 " OldFile))
(vl-cmdf "saveas" "2004" OldFile)
(setvar "expert" 0)
Krushert
« Reply #2 on: April 11, 2006, 09:23:05 AM »
Thanks Keith.
Thanks for showing me about the “vl-cmdf” function.  Last night I look it up Vlisp help and can understand how that function came about.
I basically pasted in your suggested code, tweaked a few minor bugs that popped up and it works great.  One of the bugs that came across is listed below.  I got it to work but don’t understand why it is needed.  I had to add the “Line 1” code (not really line 1 in the routine) so that Lines 2 & 4 could work.  Why do I need to preset the variable “which_action” to one when Line 2 sets the variable “which_action” to 1 again?
Why?  I am just asking so I can understand.
Line 1 =  (setq which_action 1)
Line 2 =  (action_tile "rb1" "(setq which_action 1)")
Line 3 = ;New version 2004 file with date Prefix
Line 4 =  (action_tile "rb2" "(setq which_action 2)")
Line 5 = ;New version 2000 file with date Prefix
Thanks again
Ted
Oh by the way; my IT guy thanks you too.
« Reply #3 on: April 11, 2006, 09:30:22 AM »
It shouldn't ... but as long as it works ...
GDF
« Reply #4 on: April 11, 2006, 11:21:47 AM »
Keith
change:
to:
(action_tile "rb1" "(command \"Wblock\" NewFile \"*\")")
Gary
« Reply #5 on: April 11, 2006, 11:31:10 AM »
Keith
change:
to:
Gary
Nope ....
Quote from: AutoLISP Reference in AutoCAD help file
NOTE You cannot call the AutoLISP command function from the action_tile function.
GDF
« Reply #6 on: April 11, 2006, 11:56:51 AM »
Keith
change:
to:
Gary
Nope ....
You can call me bonehead. Of course you are correct. I was only refering to the \" and should have
spotted the command in the action tile.
I'm going across the street for some more coffee, now...
Gary
