Author Topic: associative dimensions  (Read 2783 times)
Humbertogo
« on: April 07, 2006, 06:47:31 AM »
Is there a way to create associative  dimensions using vb
Chuck Gabriel
Re: associative dimensions
« Reply #1 on: April 07, 2006, 08:05:40 AM »
Sure.  Have a look at the following methods of the AcadBlock class:
AddDim3PointAngular
AddDimAligned
AddDimAngular
AddDimDiametric
AddDimOrdinate
AddDimRadial
AddDimRotated
Not sure if DimAssoc (or DimAso) has to be turned on for these to be created as associative.
Humbertogo
« Reply #2 on: April 07, 2006, 08:32:07 AM »
Where
 use the following methods and properties
ArrayPolar
ArrayRectangular
Copy
Delete
GetBoundingBox
GetExtensionDictionary
GetXData
Highlight
IntersectWith
Mirror
Mirror3D
Move
Rotate
Rotate3D
ScaleEntity
SetXData
TransformBy
Update
 Properties
AltRoundDistance
AltSuppressLeadingZeros
AltSuppressTrailingZeros
AltSuppressZeroInches
AltSuppressZeroFeet
AltTextPrefix
AltTextSuffix
AltTolerancePrecision
AltToleranceSuppressLeadingZeros
AltToleranceSuppressTrailingZeros
AltToleranceSuppressZeroFeet
AltToleranceSuppressZeroInches
AltUnitsFormat
AltUnits
AltUnitsPrecision
AltUnitsScale
Application
Arrowhead1Block
Arrowhead1Type
Arrowhead2Block
Arrowhead2Type
ArrowheadSize
DecimalSeparator
DimensionLineColor
DimensionLineExtend
DimensionLineWeight
DimLine1Suppress
DimLine2Suppress
DimLineInside
Document
ExtensionLineColor
ExtensionLineExtend
ExtensionLineOffset
ExtensionLineWeight
ExtLine1Point
ExtLine2Point
ExtLine1Suppress
ExtLine2Suppress
Fit
ForceLineInside
FractionFormat
Handle
HasExtensionDictionary
HorizontalTextPosition
Hyperlinks
Layer
LinearScaleFactor
Linetype
LinetypeScale
Lineweight
Measurement
Normal
ObjectID
OwnerID
PlotStyleName
PrimaryUnitsPrecision
Rotation
RoundDistance
ScaleFactor
StyleName
SuppressZeroFeet
SuppressZeroInches
TextColor
TextGap
TextHeight
TextInside
TextInsideAlign
TextMovement
TextOutsideAlign
TextOverride
TextPosition
TextPrefix
TextRotation
TextStyle
TextSuffix
ToleranceDisplay
ToleranceHeightScale
ToleranceJustification
ToleranceLowerLimit
TolerancePrecision
ToleranceUpperLimit
TrueColor
UnitsFormat
VerticalTextPosition
Visible
 Events
Modified
Chuck Gabriel
« Reply #3 on: April 07, 2006, 08:58:01 AM »
That is a very vague question.  What exactly are you trying to accomplish?
Humbertogo
« Reply #4 on: April 07, 2006, 09:09:50 AM »
I just try to find the properties
