Author Topic: a whole new world (well kinda)  (Read 5502 times)
uncoolperson
« on: April 06, 2006, 04:14:10 PM »
so i'm still in the acad 2005 world, will the visual studio 2005 express editions play well with this?
and about this:
"Interactive Debugging for ACAD is not enabled."
that's the whole stepping through stuff right?
MickD
Re: a whole new world (well kinda)
« Reply #1 on: April 06, 2006, 04:47:12 PM »
One of the good things with .net is you can use almost any compiler version to build your solutions (so far) given the right .net version of course so vse2005 should be fine.
Yep, that's the steppen' through stuff thing, but there are work arounds such as using throw/catch blocks and simple messages at suspect lines of code but it would be good to 'watch' your variables some times but again you could use a simple message box or print to command line to view these values at runtime.
hth
- John Carmack
- J.R.R. Tolkien
« Reply #2 on: April 06, 2006, 04:48:19 PM »
Yes
and
yes
uncoolperson
« Reply #3 on: April 06, 2006, 07:17:17 PM »
okay, one last question
you ready for all my questions relating to this?
« Reply #4 on: April 06, 2006, 07:36:49 PM »
silence was the loudest reply :-)
MickD
« Reply #5 on: April 06, 2006, 07:39:57 PM »
heh ^
bring 'em on!
- John Carmack
- J.R.R. Tolkien
uncoolperson
« Reply #6 on: April 13, 2006, 11:09:42 AM »
they installed c## rather than C++
dangit!
« Reply #7 on: April 13, 2006, 03:16:54 PM »
dangit!
who is they
and what is c## ?
uncoolperson
« Reply #8 on: April 13, 2006, 06:20:31 PM »
IT
and i'm stupid...
« Last Edit: April 13, 2006, 06:42:29 PM by uncoolperson »
nivuahc
« Reply #9 on: April 13, 2006, 09:22:17 PM »
IT
and i'm stupid...
It happens to the best of us. :)
My opinion: They did you a favor installing C# instead of C++. And I've come to that conclusion based on my extensive research, reading. and intense studying of the two languages (i.e. a few minutes of reading here or there over the past day and a half) ;)
