I had made some trials and ANGDIR does not change the POLAR angle orientation.
Why I want to do so?
Drawing elbosw it can be drawn in both directions .
Does not matter if ANGDIR is 0 or 1 it allwais draw the elbows CCW , I want to draw it in any one direction CCW or CW
Please see the following code, please apologize me for the so scrach way to LISP
(defun z9 () ;USE IT AFTER DRAWING ANY THING SO YOU CAN SEE IF IT IS OUT OF SCREEN
(COMMAND "._zoom" "E") ;ZOOM TO EXTENT
(COMMAND "VIEWRES" "Y" 15000)
(COMMAND "._ZOOM" "0.9X") ; ZOMM TO 0.9 SCALE
(SETQ VAR 0)
(DEFUN PR1 (name value )
(SETQ VAR (1+ VAR))
(prinT "this variable.....")
(PRIN1 VAR)
(PRINT "---------------------")
(Print name)
(prinT "have this value...")
(prinT value)
) ;end defun pr1
;_RAD TO DEG AND DEG TO RAD
(defun RTD (X) ;define RADIAN TO DEGREE function
(/ (* X 180.0) P) ; MULTIPLY THE RAD ING BY 180 AND DIVIDE IT BY PI
);_end rtd
(defun DTR (X) ;define DEGREE to RADIAN function
(/ (* X p) 180.0)
) ;_end dtr
(DEFUN FIJ ()
;(SETQ ALFA 0.0)
(SETQ A 12.0) ;12 IS THE A DUCT SIZE
(pr1 "aaa " a)
(SETQ B 12.0)
(pr1 "bbbb " B)
(SETQ URIG (LIST 0.0 0.0 0.0)) ;THIS IS THE C RADIOUS CENTER , AT 0X 0Y 0Z
(pr1 "URIG " URIG)
(SETQ ALFA 90.0) ;ORIENTATION ANGLE
(pr1 "ALFA " ALFA)
(setvar "angdir" 1)
(setq ang# -90)
(pr1 "ANG# ... " ANG#)
;;;(setvar "angdir" 0)
;;;(setq ang# 90)
);_end
;_START THE CALCS
(DEFUN CALC ()
(PR2)
(SETQ C (* A 1.5)) ;IT IS THE C RADIOUS AS 1.5 OF A
(pr1 "CCCC " C)
(SETQ D (* A 0.25)) ; THE ELLBOW'S STRAIGHT PART
(pr1 "DDDD.... " D)
(setq pt1 urig)
(pr1 "PT1 ... " PT1)
(setvar "pdmode" 34)
(setvar "pdsize" 2)
(command "point" pt1)
(setq alfa (dtr alfa)) ;CONVERT ALFA FROM DEGREE TO RADIAN
(pr1 "alfa " alfa)
(setq alfa (- alfa))
(pr1 "--alfa " alfa)
(setq pt2 (polar pt1 (+ alfa p270) a))
(pr1 "PT2 " PT2)
(setq pt3 (polar pt2 (+ alfa p180) d))
(pr1 "PT3 " PT3)
(Setq pt4 (polar pt3 (+ alfa p2) a))
(pr1 "PT4 " PT4)
(command "line" pt1 pt2 pt3 pt4 "c")
(setq pt10 (polar pt3 (+ alfa p270) c))
(pr1 "PT10 " PT10)
(setq pt5 (polar pt10 (+ alfa p180) c))
(pr1 "PT5 " PT5)
(setq pt6 (polar pt5 (+ alfa p270) d))
(pr1 "PT6 " PT6)
(setq pt7 (polar pt6 (+ alfa p180) b))
(pr1 "PT7 " PT7)
(setq pt8 (polar pt7 (+ alfa p2) d))
(pr1 "PT8 " PT8)
(command "line" pt5 pt6 pt7 pt8 "c")
(command "arc" "c" pt10 pt3 pt5)
(command "arc" pt4 "E" pt8 "A" ang#)
) ;_END CALCS
(defun c:polr ()
(fij)
(calc)
(Z9)
) ;_end defun
