Author Topic: Automating Dimensioning a Single Point's Location from 0,0,0  (Read 3042 times)
Humbertogo
« on: April 05, 2006, 12:42:12 PM »
I am trying to automate dimensioning a Single Point's Location
I want to dimension a single point relative to  0,0,0
Any help would be greatfully appreciated.
Bryco
Re: Automating Dimensioning a Single Point's Location from 0,0,0
« Reply #1 on: April 05, 2006, 12:54:06 PM »
What kind of dimension do you want to use?
Humbertogo
« Reply #2 on: April 05, 2006, 01:05:20 PM »
AcadDimRotated
joseguia
« Reply #3 on: April 05, 2006, 01:14:34 PM »
so what kind of problem are you having? Where are you stuck?
Humbertogo
« Reply #4 on: April 05, 2006, 01:20:43 PM »
I don't any idea how to starting :-D at the moment i think i have brain dead :realmad:
joseguia
« Reply #5 on: April 05, 2006, 01:30:20 PM »
Straight from F1-University
Sub Example_AddDimRotated()
    ' This example creates a rotated dimension in model space.
    Dim dimObj As AcadDimRotated
    Dim point1(0 To 2) As Double
    Dim point2(0 To 2) As Double
    Dim location(0 To 2) As Double
    Dim rotAngle As Double
    ' Define the dimension
    point1(0) = 0#: point1(1) = 0#: point1(2) = 0#
    'Use CODE to Find out where the Second POINT should go
    point2(0) = 5#: point2(1) = 5#: point2(2) = 0#
    location(0) = 0#: location(1) = 5#: location(2) = 0#
    rotAngle = 0 '(or the angle you want)
    rotAngle = rotAngle * 3.141592 / 180#       ' covert to Radians
    ' Create the rotated dimension in model space
    Set dimObj = ThisDrawing.ModelSpace.AddDimRotated(point1, point2, location, rotAngle)
    ZoomAll
End Sub
« Last Edit: April 05, 2006, 01:36:54 PM by joseguia »
CADaver
« Reply #6 on: April 05, 2006, 01:51:17 PM »
Is there some reason you don't want to use ORDINATE dims? or is this a programming exercise?
Humbertogo
« Reply #7 on: April 05, 2006, 03:13:00 PM »
Thank  i know again  :-D
I forgot to  convert the two point to an angel :-D
