Author Topic: Selection sets  (Read 16018 times)
sbattina
Selection sets
« on: February 20, 2004, 02:47:15 PM »
I am trying to work on selection sets. The code below is what I have used. But it does not show the selection window. It gives me a line from the first point to the second. How can get the user to see the selection window??
Public Sub SelectObject()
Dim ssetName As String
Dim objSet As AcadSelectionSet
Dim intMode As Integer
Dim ObjLayer As AcadLayer
Dim Pt1, Pt2
Dim dblPt3(0 To 2) As Double
Dim objEnt As Object
ssetName = "A1"
On Error Resume Next
' deleting existing sset A1 if any
ThisDrawing.SelectionSets("A1").Delete
Set objSet = ThisDrawing.SelectionSets.Add(ssetName)
intMode = acSelectionSetCrossing
frmMain.Hide
Pt1 = ThisDrawing.Utility.GetPoint(, "select lower left point to window selection set:")
Pt2 = ThisDrawing.Utility.GetPoint(Pt1, "select Upper Right point to window selection set:")
objSet.Select intMode, Pt1, Pt2
For Each objEnt In objSet
If TypeOf objEnt Is AcadEntity Then
Set ObjLayer = ThisDrawing.Layers.Add("ABC")
ObjLayer.color = acBlue
objEnt.Layer = "ABC"
End If
Next objEnt
ThisDrawing.SelectionSets.Item(ssetName).Delete
Application.Update
Selection sets
« Reply #1 on: February 20, 2004, 11:33:43 PM »
You should really use the SelectOnScreen method instead of select and passing points.
Try this
ssetName = "A1"
frmMain.Hide
objSet.SelectOnScreen
End If
Next objEnt
Application.Update
I have not tested it, but it should work fine.
Incedently I removed the unused variables.
I might add that is is always good practice to use the AcadApplication object as opposed to Application. This prevents an error if the program is ever used within another VBA enabled program, excel for example.
TR
Selection sets
« Reply #2 on: February 21, 2004, 02:28:24 AM »
You should try to stay away from "On Error Resume Next".
Selection sets
« Reply #3 on: February 21, 2004, 09:00:50 AM »
mohan
Re: Selection sets
« Reply #4 on: March 16, 2016, 11:14:47 AM »
ssetName = "A1"
frmMain.Hide
End If
Next objEnt
Application.Update
Hello guys;
Please explain from begining how to run the visual basic programming code
if you don't mind
Mohan
"Save Energy"
ChrisCarlson
