Author Topic: Adding a suffix to text  (Read 4922 times)
Kate M
« on: February 20, 2004, 10:30:56 AM »
I need to add " (E)" to about 200 beam designations -- they're all just single line text...any takers? :-) (This isn't really urgent, I'm just being lazy. :-))
« Reply #1 on: February 20, 2004, 10:50:01 AM »
email me the dwg, i'll do it.
mark.thomas@tampagov.net
SMadsen
« Reply #2 on: February 20, 2004, 11:00:26 AM »
Mark, you've got too much time on your hands .. first a batch of DGN's then ..
Is that guy helpful or what?
Kate M
« Reply #3 on: February 20, 2004, 11:03:24 AM »
Hmm...not sure I'm allowed...thanks, though. :-) I thought TCOUNT might be work, but you have to use numbers.
SMadsen
« Reply #4 on: February 20, 2004, 11:10:18 AM »
Find/replace maybe?
Kate M
« Reply #5 on: February 20, 2004, 11:14:13 AM »
Could work, but there's a bunch of different sizes -- probably still faster than typing it all in individually. :-)
« Reply #6 on: February 20, 2004, 11:27:57 AM »
anything common with all the text?
daron
« Reply #7 on: February 20, 2004, 11:30:00 AM »
You do know that you can select all the objects you want to replace? Seems like the long way, but it is still quicker than selecting each object then locating the spot, then typing the change. Which can get annoying real quick.
SMadsen
« Reply #8 on: February 20, 2004, 12:29:37 PM »
Oh well, forgot find/replace doesn't take wildcards. Sorry.
Here you go (change the "(22)" text to any suffix you want) - single line text only:
(defun C:go22 ()
  (cond ((setq sset (ssget '((0 . "TEXT"))) a 0)
         (while (setq ent (ssname sset a))
           (setq entl (entget ent) a (1+ a))
           (entmod (subst (cons 1 (strcat (cdr (assoc 1 entl)) "(22)"))
                          (assoc 1 entl)
                          entl)
SMadsen
« Reply #9 on: February 20, 2004, 12:31:54 PM »
Don't know where I got "(22)" from .. hmm  :roll: .. should've been " (E)" I see.
« Reply #10 on: February 20, 2004, 12:43:02 PM »
Try this and use zero as the increment.
AutoNumb
DParcon
« Reply #11 on: February 20, 2004, 01:21:16 PM »
If the text to be changed are AISC beam designations,
try this routine or tweaked it to your needs:
(defun C:CHT ()
  (if (setq ss (ssget '((0 . "TEXT") (1 . "*X*"))))
    (while (setq e (ssname ss 0))
      (setq str (cdr (assoc 1 (setq ed (entget e))))
            str (strcat str "(E)")
      (entmod (subst (cons 1 str) (assoc 1 ed) ed))
      (entupd e)
      (ssdel e ss)
    );while
    (prompt "No Text to be changed..")
Kate M
« Reply #12 on: February 20, 2004, 04:39:31 PM »
I ended up just using find/replace, first to find all the different sizes, then to tack on the suffix -- but I'll definitely try out some of the code suggestions for the next time I forget to label all the existing beams. :-)
Thanks again for all the ideas!
-Kate
