Author Topic: Challenge ( cylinder volume )  (Read 5924 times)
« on: March 31, 2006, 11:29:56 AM »
Calculate the volume of a cylinder given diameter and height. However, to make it a challenge you can not use any variables. You must prompt the user for for both diameter and height, include error checking for negative numbers, zero and <enter>. Local functions are allowed.
have fun!
Re: Challenge ( cylinder volume )
« Reply #1 on: March 31, 2006, 11:36:37 AM »
<sitting on hands for now>
 :evil:
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #2 on: March 31, 2006, 12:09:38 PM »
Whether truly I have understood, what it is impossible to use SETQ?
« Reply #3 on: March 31, 2006, 12:12:04 PM »
If I understand Mark's intent, and I believe I do, he meant you cannot use set or setq.
« Reply #4 on: March 31, 2006, 12:19:55 PM »
For fun I offer --
(defun c:foo ( )
    (princ
        (strcat "Volume of cylinder = "
            (rtos
                (   (lambda ( foo )
                        (*  pi
                            (expt (foo "\nEnter radius: ") 2)
                            (foo "\nEnter height: ")
                    (lambda ( pmt ) (initget 7) (getdist pmt))
« Reply #5 on: March 31, 2006, 12:24:43 PM »
Another fun variant --
(defun c:foo ( / foo )
    (defun foo ( pmt ) (initget 7) (getdist pmt))
    (princ
            (rtos
                (   (lambda ( radius height )
                        (*  pi
                            (expt radius 2)
                            height
« Reply #6 on: March 31, 2006, 12:32:54 PM »
And for a daffy combination of the two previous variants --
(defun c:foo ( )
    (princ
            (rtos
                (   (lambda ( foo )
                                (*  pi
                                    (expt radius 2)
                                    height
:P
whdjr
« Reply #7 on: March 31, 2006, 12:35:41 PM »
Here's mine:
;Calculate the volume of a cylinder given diameter and height. However,
 ;to make it a challenge you can not use any variables. You must prompt
 ;the user for for both diameter and height, include error checking for
 ;negative numbers, zero and <enter>. Local functions are allowed.
 ;Cylinder pi * radius2 * height
(defun c:cylinder (/ ask sq)
 (defun ask (msg)
  (initget 7)
  (getreal msg)
 (defun sq (num)
  (* num num)
 (princ
  (strcat "\nCylinder Volume:    "
  (rtos (* pi
   (sq (ask "\nEnter Diameter for Cylinder:  "))
   (ask "\nEnter Height for Cylinder:  ")
2
« Reply #8 on: March 31, 2006, 01:22:34 PM »
Will I'd say you copied my idea but you posted first. :-)
(defun c:cubevol ( / ask)
  (defun ask (msg)
    (initget 7)
    (getreal msg)
  (princ
    (strcat "Volume = "
            (rtos
                (* pi
                   (expt (/ (ask "\nDiameter: ") 2) 2)
                (ask "\nHeight: ")
« Reply #9 on: March 31, 2006, 05:29:59 PM »
Nice challenge Mark .. :-)
RbtDanforth
« Reply #10 on: March 31, 2006, 05:39:34 PM »
There was once a tale told of WW2 in the Pacific, The Japanese were on one side of the island and the Allies were on the other with a big jungle in the middle. The question was how to go after the Japanese.
The Aussie said "just go through the jungle and get the Japanese"
The Brit said "No, we need to go around the jungle"
The American said " Naw you are all wrong! We just remove the jungle and go get them Japs"
The Aussie lisp would be just to paste this in the command line
(* pi (getreal "raduis")(getreal "radius again")(getreal "height"))
Has the additional advantage of working with truncated cones as well :-D
RbtDanforth
« Reply #11 on: March 31, 2006, 06:18:08 PM »
On deeper thought it does has to be a cylinder or very nearly one. but there is also
'cal (sqr(radius))*pi* (height) but you have to type the radius and height in, and technically it is not lisp but it is short and sweet
LE
« Reply #12 on: March 31, 2006, 06:32:41 PM »
(apply '*
       (list (expt (cond (1 (initget 6) (getdist "\nRadius: "))) 2)
     (cond (1 (initget 6) (getdist "\nHeight: ")))))
LE
« Reply #13 on: March 31, 2006, 06:40:44 PM »
Yes I know I need glasses....  :lol:
(apply
  (list (expt (cond (1 (initget 7) (/ (getdist "\nDiameter: ") 2)))
      2)
(cond (1 (initget 7) (getdist "\nHeight: ")))))
« Reply #14 on: March 31, 2006, 06:44:18 PM »
hehehehe .. I was just posting, you spoil my fun   :cry:
