Author Topic: returned as a AcadBlockReference  (Read 4642 times)
Humbertogo
« on: March 27, 2006, 08:12:00 AM »
Is there any possibility to explode AcadBlockReference.. do some changes
in all entry and returned as a AcadBlockReference  back
Re: returned as a AcadBlockReference
« Reply #1 on: March 27, 2006, 09:06:52 AM »
Well, I suppose it is possible ... I would just have to look at how it needed to be handled to do what you are needing. If you are simply wanting to redefine a block reference, you should probably redefine the block itself in the block table. You can enumerate the individual entities in the block and modify as needed.
Dnereb
« Reply #2 on: March 27, 2006, 10:03:21 AM »
You don't need to do explode the block to do the damage.
It's possible to alter a block just like in refedit.
Humbertogo
« Reply #3 on: March 27, 2006, 10:47:14 AM »
Pls explame more about
Bryco
« Reply #4 on: March 28, 2006, 12:46:59 AM »
Hi Humbertogo
Make a block with a circle and run this
Sub BlockEdit()
    Dim oBlocks As AcadBlocks
    Dim oBlock As AcadBlock
    Dim oBref As AcadBlockReference
    Dim Ent As AcadEntity
    Dim V, BlockEnt As AcadEntity
    Set oBlocks = ThisDrawing.Blocks
    ThisDrawing.Utility.GetEntity Ent, V, "Pick a blockreference:"
    If TypeOf Ent Is AcadBlockReference Then
        Set oBlock = oBlocks(Ent.Name)
        For Each BlockEnt In oBlock
            If TypeOf BlockEnt Is AcadCircle Then
                BlockEnt.radius = BlockEnt.radius * 2
                BlockEnt.Color = acRed
                Ent.Update
                Exit For
            End If
        Next BlockEnt
    End If
End Sub
I remember wanting to explode blocks to find the arcs and the lines, if you need that I have some stuff
Jürg Menzi
  • Oberegg, Switzerland
« Reply #5 on: March 28, 2006, 01:19:32 AM »
Remember that you can't explode NUS blocks with the Explode method since A2k4...
A computer's human touch is its unscrupulousness!
MENZI ENGINEERING GmbH
Current A2k16... A2k24 - Start R2.18
Bryco
« Reply #6 on: March 28, 2006, 10:29:31 AM »
Ouch didn't know that. Now another function to make.
Humbertogo
« Reply #7 on: March 30, 2006, 08:53:34 AM »
Thanks again
