What is the secret to keep toolbars where they are when you close AutoCad? I had too much screen area being used up by unused AutoCad tools on the default toolbars, so I took the time and made me some new toolbars with just the tools that IO use on a regular basis. Now when I open AutoCad some of the tools are in a different location from where they were when I closed AutoCad, however they are in the same location each time and it is the same toolbars that are relocated.
My question is, Is there a magic switch that can fix my problem?
I know in the old mnu files you could specify the location of toolbars there but I'm not sure where to look now.
Please help....
