Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Reading attribute Value before insertion.
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Reading attribute Value before insertion. (Read 2152 times)
Shade
Guest
on:
March 20, 2006, 07:48:38 AM »
Is there a way of getting an attributes value from a block before the block has been inserted or do I have to insert the block first read the attributes value then erase the block and insert it again?
I wish to store the following info in the attributes of a block;
-Unit type = Metric or Imperial
-Layer group = Default layer placement
I am writing a lisp that will insert a block in the proper units and place that block on the layer I choose by default.
Any help would be appreciated...
Logged
Mesozoic relic
Seagull
class keyThumper<T>:ILazy<T>
Re: Reading attribute Value before insertion.
Reply #1 on:
March 20, 2006, 08:10:09 AM »
Yes, you could read the tag values from the block in the BlockTable/blockCollection,
but, you could also change the scale and Layer after the INSERT is placed, which may be simpler.
Logged
FengK
Guest
Reply #2 on:
March 21, 2006, 02:29:34 AM »
If the block definition is in the drawing, you can easily examine it.
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(setq blkDef (vla-item (vla-get-blocks doc) blkName))
If not, you can open the block drawing with ObjectDBX and step through the objects. There should be many examples of using ObjectDBX in Autodesk ng.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
