Author Topic: Add row in a Table - Question  (Read 10072 times)
LE
« on: March 16, 2006, 09:30:10 PM »
What method, should I need to use in order to have the new row added, in real time ?
When I run the below code, it does work but I need to select [grip], the table in order to have the Table updated.
Thanks!
static void LESQsomefunctions_ADDROW(void)
ads_name ename;
ads_point ptres;
if ( acedEntSel( "\nSelect TABLE:", ename, ptres ) == RTNORM ) {
AcDbTable *pTable = NULL;
AcDbObjectId entId;
acdbGetObjectId( entId, ename );
acdbTransactionManager->startTransaction();
if ( acdbTransactionManager->getObject(
( AcDbObject*& )pTable, entId, AcDb::kForRead) == Acad::eOk) {
if ( pTable->isKindOf( AcDbTable::desc() ) ) {
pTable->upgradeOpen();
if (( pTable->insertRows( pTable->numRows(),
pTable->rowHeight( 1 ) ) == Acad::eOk ) &&
( pTable->generateLayout() == Acad::eOk )) {
acutPrintf( "\nAdded one row and table updated." );
} else {
acutPrintf( "\nTable not updated." );
}// end of is AcDbTable
}// end of getObject
acdbTransactionManager->endTransaction();
}// end of acedEntSel
}//end of command ADDROWS
Re: Add row in a Table - Question
« Reply #1 on: March 16, 2006, 09:35:41 PM »
Do you need to Commit   the transaction in CPP ?
--> Donate to theSwamp<--
LE
« Reply #2 on: March 16, 2006, 09:46:29 PM »
That is not available as function on ARX, I know what that function does in .NET, now what happens is that it is needed to wait for the transactionEnded() signal and after that, do the modifications... hmm...
It is contradictory, since when it is used the transaction manager, the good about it is to not care of closing objects.... unless [and it is possible] I am wrong...
I will change my code to use smart pointers... and see what happens.
Thanks.
  • (x-in)->[process]->(y-out)
« Reply #3 on: March 16, 2006, 09:51:15 PM »
it seems .net commit wraps the ::endTransaction() method.
from the doc's
virtual Acad::ErrorStatus
endTransaction() = 0;
Ends the top transaction, committing all changes to objects obtained within that transaction. Also clears the undo marker associated with the transaction out of the undo file for all transaction-resident objects (this means resident in any transaction).
Luis, does it work with a regen in the editor??
Lao Tzu: “To attain knowledge, add things
every day; to obtain wisdom, remove things every day.”
LE
« Reply #4 on: March 16, 2006, 09:58:15 PM »
from the doc's
It is the same part of the help that I just read, my friend.... editor [drawing session?]... no it does not do it magically..... as Kerry mentioned...
Grrrrr......
LE
« Reply #5 on: March 16, 2006, 10:03:54 PM »
Got it... here is the code that works, using smart pointers!
ads_name ename;
ads_point ptres;
Acad::ErrorStatus es;
AcDbObjectId objId;
acdbGetObjectId( objId, ename );
AcDbObjectPointer<AcDbTable> pTable( objId, AcDb::kForWrite );
if ( ( es = pTable.openStatus() ) == Acad::eOk ) {
pTable->rowHeight( 1 ) ) == Acad::eOk) &&
} else {
acutPrintf("\nIt is not a TABLE or it can not be opened: %s",
acadErrorStatusText( es ) );
« Reply #6 on: March 16, 2006, 10:17:52 PM »
hmm, loose memory, no good 'ay.
sort of, the editor as I referred to it is just that, the place where the user edits the currently active document and is an object in its own right (a Windows UI object).
The only time you should use the editor is for user interaction/input otherwise everything else can be done directly on the database object. That's why it's not good practice to use sendCommand etc. as you're playing with an interface to a different object (Windows) and could cause unnecessary overhead and troubles ;)
LE
« Reply #7 on: March 16, 2006, 10:25:20 PM »
Thanks Mick;
On my previous code using the transaction manager, it is not possible, it has to be done following the normal way of opening an object, do the changes and later closing them, Or go the smart pointer route...
I can see the magic Kerry was referring....  :-)
Alexander Rivilis
  • Programmer from Kyiv (Ukraine)
« Reply #8 on: March 17, 2006, 04:45:59 AM »
Thanks Mick;
You was not right. You Can use transaction manager. Look at this code and compare with yours code:
  static void TableAddRow(void)
    ads_name ename;
    ads_point ptres;
    if ( acedEntSel( "\nSelect TABLE: ", ename, ptres ) == RTNORM ) {
      AcDbObject *pObj = NULL;
      AcDbObjectId entId;
      if (acdbTransactionManager->getObject(pObj, entId, AcDb::kForWrite) == Acad::eOk) {
        AcDbTable *pTable = AcDbTable::cast(pObj);
        if (pTable &&
            pTable->insertRows(pTable->numRows(),pTable->rowHeight(1)) == Acad::eOk &&
            pTable->generateLayout() == Acad::eOk) {
        } else {
In other words You can not use acdbTransactionManager->getObject(...,AcDb::kForRead) and after then use upgradeOpen(). upgradeOpen() is valid only with objects not in transaction.
« Last Edit: March 17, 2006, 05:01:01 AM by Rivilis »
« Reply #9 on: March 17, 2006, 04:59:09 AM »
Hello Alexander, thanks for posting.
Do you compile that as managed code only ?
Alexander Rivilis
« Reply #10 on: March 17, 2006, 05:04:12 AM »
No! I've compiled that code as native and tested it in AutoCAD 2006 SP1.
« Reply #11 on: March 17, 2006, 05:10:02 AM »
Thanks, I'm not a CPP'er really, but I had a suspicion that transaction were used with native as well as managed.
I Hope you enjoy your time here :-)
Alexander Rivilis
« Reply #12 on: March 17, 2006, 05:17:53 AM »
I'm CPP'er and Lisp'er.  And in 99.9% I'm using only native code in C++. For managed code I prefer C#. But in C# I'm beginner.
Glenn R
  • What idiot child of married cousins wrote this?!
« Reply #13 on: March 17, 2006, 06:46:45 AM »
Rivilis is quite correct Luis. You can use transactions in the code you posted. However, is it better than using smart pointer objects and checking all return codes...open for debate.
Smart pointers let you take some syntactical shortcuts in my opinion, however, transactions are Adesk's *preferred* method is transactions and have their own benefits.
The only thing I would change in Rivilis's code is to add the explicit use of abortTransaction() in the 'else' clause of the 'if' statement.
Now that I think about it, that 'if' statement is a bit unclear, so I would re-write myself. A general rule I adopted in C++ is to bail out immediately if a condition is not met...and my 'if' statements/switch etc. statement would reflect this.
Example:
if (!Whatever)
  return;
// Continue processing here.
instead of:
if (Whatever) {
  // Dome some lengthy and very much indented code here.
Just some bourbon ramblings.
Cheers,
Glenn.
P.S. I *miss* my C++.... < sigh >
Me
Alexander Rivilis
« Reply #14 on: March 17, 2006, 06:53:34 AM »
I also agree with you! :)
Another style of code:
class Trans
public:
   Trans()  { tr = acTransactionManagerPtr()->startTransaction(); }
  ~Trans()  {
    if (tr == acTransactionManagerPtr()->topTransaction()) {
      acTransactionManagerPtr()->endTransaction();
  AcTransactionManager *operator->() {return acTransactionManagerPtr();};
private:
  AcTransaction *tr;
class TransExpt {};
  ads_name ename;
  ads_point ptres;
    AcDbObjectId entId;
    Trans tr;
    try {
      if (tr->getObject(pObj, entId, AcDb::kForWrite) != Acad::eOk)
        throw TransExpt();
      if (!pTable)  throw TransExpt();
      if (pTable->insertRows(pTable->numRows(),pTable->rowHeight(1)) != Acad::eOk)
        throw TransExpt();
      if (pTable->generateLayout() != Acad::eOk)
        throw TransExpt();
      tr->flushGraphics();
    catch (TransExpt) {
      tr->abortTransaction();
« Last Edit: March 17, 2006, 08:43:58 AM by Rivilis »
