Author Topic: xref'd layer name  (Read 7783 times)
rude dog
xref'd layer name
« on: February 18, 2004, 09:48:33 AM »
How would you extract out a xref'd layer name...It seems to me the dxf codes do not work with these nested layer names? :?:
SMadsen
xref'd layer name
« Reply #1 on: February 18, 2004, 09:59:07 AM »
?? Can you give an example?
rude dog
xref'd layer name
« Reply #2 on: February 18, 2004, 10:24:35 AM »
(setq ES (car (entsel "\nPick layer to keep thawed <Enter to exit>:")))
(setq EL (cdr (assoc 8 (entget ES))));extracts out layer names
This approach does not work on layers that are contained within the xref
usually I do invoke "xlist" command and pick on the entity and it brings up a dialog box showing the nested xref layer name...I was trying to think of a universal way to pull out layer names wheter they have been xref'd in or not
any idea's[/code]
SMadsen
xref'd layer name
« Reply #3 on: February 18, 2004, 10:30:16 AM »
Ahh, now I understand. It's just like when you pick a block with ENTSEL, you won't get info about the subents but only the insert.
Try looking into NENTSEL instead of ENTSEL.
rude dog
xref'd layer name
« Reply #4 on: February 18, 2004, 10:35:09 AM »
Ill check it out..thanks
SMadsen
xref'd layer name
« Reply #5 on: February 18, 2004, 10:53:48 AM »
you're welcome.
Of course, you can also combine the methods so that if the user hits a block, it'll dig down and get the subent's layer - otherwise it'll just return the layer name.
ENTSEL returns the picked point, which NENTSELP can use to find a subent if need be:
(defun getLayer (/ ent entl ient layer)
  (cond ((setq ent (entsel))
         (setq entl (entget (car ent)))
         (and (= "INSERT" (cdr (assoc 0 entl)))
              (setq ient (nentselp (cadr ent)))
              (setq entl (entget (car ient)))
  (if (and entl (setq layer (cdr (assoc 8 entl))))
    (princ layer)
xref'd layer name
« Reply #6 on: February 18, 2004, 11:30:46 AM »
Here's an ActiveX method. could use some more testing
(defun return-vla-object (/ util-obj msg just-in-case vlaobj
                            pt-var tran objids)
  (setq util-obj (vla-get-utility
  (setq msg (vlax-make-variant "Select Object: "))
  (setq just-in-case
        (vl-catch-all-apply
          'vlax-invoke-method
          (list util-obj 'GetSubEntity 'vlaobj 'pt-var 'tran
                'objids msg)
  (if (not (vl-catch-all-error-p just-in-case))
    vlaobj
rude dog
xref'd layer name
« Reply #7 on: February 18, 2004, 11:48:07 AM »
its really cool to see different renditions...have to study both of these for a while....my brain overflowth :)
xref'd layer name
« Reply #8 on: February 18, 2004, 12:12:38 PM »
You'll need something like this to the layer name using my example.
(defun get-layer-name (/ obj layname)
  (if (setq obj (return-vla-object))
    (setq layname (vlax-get-property obj 'Layer)))
xref'd layer name
« Reply #9 on: February 18, 2004, 12:35:29 PM »
Thanks Stig, I'm borrowing another  routine from you. :)
Did change it to return the layer name. OK?
;;; Returns layer of selected object
;;;    nil if nothing selected
(defun c:getLayer (/ ent entl ient)
  (cond ((setq ent (entsel "\nPick object to find layer."))
PS could you remove ient without harm?
SMadsen
xref'd layer name
« Reply #10 on: February 18, 2004, 01:08:05 PM »
Don't see why not, CAB .. I mean both the shortened version and replacing ient with ent should work fine.
xref'd layer name
« Reply #11 on: February 18, 2004, 02:09:30 PM »
The reason I asked is that using AND that way is still a little
new to me and I wasn't sure if there would be a case when
might fail. Leaving it wouldn't hurt either, makes it more
readable to me. I guess I get on the "Condense Everything" kick
sometimes.
Not meaning to over analyze your code, but I have found subtleties
in you code that I missed on the first go around. So if my inquiries
get bothersome please tell me.
SMadsen
xref'd layer name
« Reply #12 on: February 18, 2004, 02:43:42 PM »
Oh, you were thinking of something like
(setq entl (entget (car (nentselp (cadr ent)))))
or even shorter? Nah, that's not a good idea, considering ENTSEL accepts the "Last" keyword and ENTGET will then have a fit.
Actually there is a hidden trap in that situation because ENTSEL will return '(0.0 0.0 0.0) if "Last" was issued, making NENTSELP search in that location and, in worst case, return a wrong entity!!
Anyway, there is no reason why ient shouldn't be replaced by ent - leaving out a single local var - but you have to verify the ename before trying to ENTGET it because it can fail (or you can catch errors with VL-CATCH.... but then it gets even longer)
Analyze away. It's only good to get some discussions instead of just tossing finished code around.
xref'd layer name
« Reply #13 on: February 18, 2004, 03:15:20 PM »
Quote from: SMadsen
Exactly what I was thinking. :)
That one had not occured to me, I rarely use it, don't know why.
Glad you pointed out the pit falls though.
You mean recycleing the var like this.
              (setq ent (nentselp (cadr ent)))
I'm Glad I asked.
xref'd layer name
« Reply #14 on: February 18, 2004, 07:05:15 PM »
Ahh, Mark :shock: What is that? ..."getsubentity"????!!! (where did that come from?!)
