Author Topic: zoom extend when changing layout..  (Read 2146 times)
Andrea
« on: March 16, 2006, 02:16:13 PM »
Hi all...
in a drawing...
it alway zoom extend when changing layout...
is there any variable to set for this ?
also, it regen the drawing each time....even the variable regenauto set to off.
Keep smile...
Re: zoom extend when changing layout..
« Reply #1 on: March 16, 2006, 02:24:57 PM »
Try setting "ucsfollow" to 0 in all layouts.
Andrea
« Reply #2 on: March 16, 2006, 03:02:27 PM »
wow...
thanks T.Willy..
did the job.
 :roll:
Keep smile...
« Reply #3 on: March 16, 2006, 03:14:58 PM »
You're welcome.  That happened to me once in like three or four viewports.  That was the worst.  Filed that one away.
Andrea
« Reply #4 on: March 16, 2006, 03:47:13 PM »
Just a little more thing...
this is happen also if we are in TILEMODE 0
when trying to enter in a no-locked Mview...
it zoom extent the Vport each time..
is there another variable for this ?
Keep smile...
« Reply #5 on: March 16, 2006, 03:54:01 PM »
I don't have time to explain the following, and I apologize for that, but I wrote this quick and dirty several years ago at the request of my users, and they expressed much gratitude.
(defun c:UCSClassic ( / _ForEachVP _DoIt _Main )
    (defun _ForEachVP (quoted_task / vps)
        (setq vps
            (apply 'append
                (mapcar
                   '(lambda (x / v) (if (/= 1 (setq v (car x))) (list v)))
                    (reverse (vports))
        (if (eq 0 (getvar "tilemode"))
                (   (eq 1 (getvar "cvport"))
                        (   vps
                            (command ".mspace")
                            (_ForEachVp quoted_task)
                            (command ".pspace")
                    (foreach x vps
                        (setvar "cvport" x)
                        (eval quoted_task)
            (foreach x vps
                (setvar "cvport" x)
                (eval quoted_task)
    (defun _DoIt ( / tilemode )
        (foreach x
           '("ucsortho" "ucsview" "ucsfollow" "ucsvp")
            (setvar x 0)
        (_ForEachVP '(setvar "ucsvp" 0))
        (princ "\nUCSORTHO has been set to 0.")
        (princ "\nUCSVIEW has been set to 0.")
        (princ "\nUCSFOLLOW has been set to 0.")
        (princ
            (strcat
                "\nFor TILEMODE = "
                (itoa (setq tilemode (getvar "tilemode")))
                " UCSVP set to 0 (off) for each active viewport."
        (princ
            (strcat
                "\nFor TILEMODE = "
                (itoa (abs (1- tilemode)))
                " UCSVP remains unaltered for each viewport."
   (defun _Main ( / cmdecho )
       (setq cmdecho (getvar "cmdecho"))
       (setvar "cmdecho" 0)
       (if (zerop (getvar "tilemode"))
                (command ".zoom" "_extents")
                (command ".mspace")
                (_DoIt)
                (command ".pspace")
                (command ".zoom" "_previous")
             (  t
                (command ".pspace")
                (_DoIt)
                (command ".mspace")
          (_DoIt)
       (setvar "cmdecho" cmdecho)
    (_Main)
Have fun.
« Reply #6 on: March 16, 2006, 03:57:08 PM »
That is what was happening to me.  Best thing to do is either
Lock the viewport
Make the vp active
setq ucsfollow to 0
exit the vp
unlock the vp
Or like Michael's code
Make the vp active
set ucsfollow to 0
zoom previous
exit the vp
