Author Topic: dim...cmdactive ?  (Read 9161 times)
Andrea
dim...cmdactive ?
« on: March 15, 2006, 09:10:30 AM »
(command "_dim")
(while (> (getvar "CMDACTIVE") 0)
(command pause)
any idea how ?
Keep smile...
kpblc
Re: dim...cmdactive ?
« Reply #1 on: March 15, 2006, 09:21:09 AM »
I don't understand what's the problem is.
Sorry for my English.
Andrea
« Reply #2 on: March 15, 2006, 09:30:59 AM »
I need to detect "dim mode"
eg:
(setq cecolor (getvar "cecolor"))
(setvar "cecolor" 1)
(while "DIMMODE" is active)...
(do nothing)
;;otherwise reset color
(setvar "cecolor" cecolor)
Keep smile...
kpblc
« Reply #3 on: March 15, 2006, 09:43:39 AM »
You can see nearly univeral error catcher at http://www.arcada.com.ua/forum/viewtopic.php?t=445 (but the resource is russian).
And at your code try this:
(defun ytty ()
  (setq _cecolor_ (getvar "cecolor"))
  (command "_.dim")
  (while (/= (logand (getvar "cmdactive") 31) 0)
    (command pause)
    ) ;_ end of while
  (setvar "cecolor" _cecolor_)
  ) ;_ end of defun
LE
« Reply #4 on: March 15, 2006, 10:18:54 AM »
Just curios, is that a forum like this one?... Do they have ObjectARX in there ?
Thanks.
Luis.
« Last Edit: March 15, 2006, 10:37:44 AM by LE »
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #5 on: March 15, 2006, 11:32:30 AM »
LE
« Reply #6 on: March 15, 2006, 11:43:00 AM »
You can see:
http://www.autocad.ru/cgi-bin/f1/board.cgi?p=024
Спасибо
[ Я буду пробовать изучить ваш язык в будущем ]
Crank
« Reply #7 on: March 15, 2006, 07:06:06 PM »
LE
« Reply #8 on: March 15, 2006, 07:35:14 PM »
Thank you so much Sir.
Alexander Rivilis
  • Programmer from Kyiv (Ukraine)
« Reply #10 on: March 16, 2006, 06:10:12 AM »
You can see:
Спасибо
:-D If you see nickname Александр Ривилис on forum autocad.ru - it is my full name. Well come to this forum!!!
LE
« Reply #11 on: March 16, 2006, 10:07:57 AM »
Thank you, I saw your name there and went to that forum some time ago, I do not know if I can make it in there, my goal is to learn more on C++/ARX/MFC ... The problem would be the communication barrier....  :-(
At least, I will try just to post once and say HI over there...  :-)
Have fun.
LE
« Reply #12 on: March 16, 2006, 11:56:05 AM »
By the way Александр Ривилис
If you have a chance, to review the ARX code posted on the below topic, thanks!
http://www.theswamp.org/index.php?topic=9032.0
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #13 on: March 16, 2006, 12:21:30 PM »
On forum autocad.ru my nickname Евгений Елпанов.
This is my full name. Welcome to autocad.ru!
Joel Roderick
« Reply #14 on: March 16, 2006, 02:32:48 PM »
I had a similar problem and ended up using this as the command name:
_.acad_dim.dimlinear
_.acad_dim.dimaligned
etc...
