Author Topic: Adding a row to a table  (Read 11567 times)
LE
Re: Adding a row to a table
« Reply #15 on: March 16, 2006, 09:33:30 PM »
Thanks Mick, it does not work... I open a new topic on the arx forum, and removed the function from here.
Glenn R
« Reply #16 on: March 16, 2006, 10:53:12 PM »
Luis,
You may want to add this:
pSomeTablePointer->generateLayout();
Kerry, this:
Table tbl = (Table)trans.GetObject(entRes.ObjectId, OpenMode.ForWrite, true);
is probably better written like this (how I do it now):
Table tbl = trans.GetObject(entRes.ObjectId, OpenMode.ForWrite, true) as Table;
The reason..............no exception will be thrown if the direct cast fails, which it can do.
All you should do then is check tbl != null.
Just an observation.
Cheers,
Glenn.
« Reply #17 on: March 17, 2006, 12:25:03 AM »
Cheers,
Glenn.
interesting .. very elegant !
thanks Glenn.
Joel Roderick
« Reply #18 on: March 17, 2006, 09:28:24 AM »
LE,
Isn't there an udpate method?  Maybe regen the drawing?
LE
« Reply #19 on: March 17, 2006, 09:57:36 AM »
LE,
Hi Joel;
Have a look into here:
http://www.theswamp.org/index.php?topic=9125.0
The code is now working... it is in ObjectARX
Luis Esquivel
MickD
« Reply #20 on: July 03, 2006, 08:23:25 PM »
Let it be said that tables s*%k hard!
Well, it's ok now I've worked them out (for my needs anyhow) but what an effort! There is very little info on the implementation of these things with code.
Anyway, for those interested here's what works for me.
Table mTable = tr.GetObject(entRes.ObjectId,OpenMode.ForWrite)as Table;
int j = 1;
string item = "n/a";
foreach(DataRow dr in dt.Rows)
if(dr["itemno"].ToString() == "tbc")
item = j.ToString();
j++;
else
item = dr["itemno"].ToString();
mTable.InsertRows(2,1.0,1);
ed.WriteMessage("\n" + item + " " + dr["qty"]);
mTable.SetTextString(2, 0, item );
mTable.SetTextString(2, 1, dr["qty"].ToString());
mTable.SetTextString(2, 2, dr["material"].ToString());
mTable.SetTextString(2, 3, dr["length"].ToString());
mTable.SetTextString(2, 4, dr["mass"].ToString());
Note I have a title and header rows in my table style. And the output -
- John Carmack
- J.R.R. Tolkien
