Author Topic: Problems with accents in the tooltip texts ? a tip :  (Read 3180 times)
Tramber
« on: March 14, 2006, 02:03:45 PM »
I've notice that it is impossible to write words with accents such as :  é à è,...etc in use in some language.
Maybe this problemn will concern you if you don't only program ODCL in English.
Just never use the Property Wizard if you don't want to get strange results. Use the Preperties panel. That's the only way. And it works.
Andrea
Re: Problems with accents in the tooltip texts ? a tip :
« Reply #1 on: April 08, 2006, 09:36:27 AM »
some of ODS file not working well...
use the ODC.
Had same problem. (french).
Keep smile...
