Author Topic: vl-vbaload  (Read 8963 times)
Humbertogo
vl-vbaload
« on: March 07, 2006, 05:50:27 AM »
When I try to use it using the vl-vbaload, it never loads:
Command: (vl-vbaload "test.dvb")'VLIDE ; error: Automation Error. Problem
in
loading DVB file
Is there more to using this function than what is in the help file?
thanks
Jim Yadon
Re: vl-vbaload
« Reply #1 on: March 07, 2006, 06:08:21 AM »
You might try here first
I know this topic has been gone over in various incarnations and different applications in several threads.
Re: vl-vbaload
« Reply #2 on: March 07, 2006, 07:13:01 AM »
The "usual" cause for that message is the file not being found on the ACAD path.
Perhaps try something like this ;
(if (setq tmp (findfile "test.dvb"))
  (vl-vbaload tmp)
  ;; else
  (prompt "\n Unable to find file")
ElpanovEvgeniy
  • Moscow (Russia)
Re: vl-vbaload
« Reply #3 on: March 07, 2006, 07:28:37 AM »
(if (vl-catch-all-error-p
      (vl-catch-all-apply
'vl-vbaload
(list
) ;_  list
      ) ;_  vl-catch-all-apply
    ) ;_  vl-catch-all-error-p
  (vl-vbaload
    (list
      (getfiled "Select a VBA File \"test.dvb\"" "" "dvb" 8)
    ) ;_  list
  ) ;_  vl-vbaload
Humbertogo
Re: vl-vbaload
« Reply #4 on: March 07, 2006, 08:26:14 AM »
it seen that i can not load the function from the acaddoc.lsp
when i load it from the vlisp editor or from the appload command the function
is working OK
i use
;(load "test")
 (vl-load-all "test.lsp")
but isn't load
kpblc
Re: vl-vbaload
« Reply #5 on: March 07, 2006, 08:37:58 AM »
I think the best way is load your application through _appload window. I prefer do not change acaddoc.lsp and acad.lsp files.
Sorry for my English.
Jürg Menzi
  • Oberegg, Switzerland
Re: vl-vbaload
« Reply #6 on: March 07, 2006, 09:19:46 AM »
My 2¢:
(vl-vbarun "MyVba.dvb!MyModul.MySub")
Load and start in one step...
There are some known problems if the dvb is loaded on startup...
MENZI ENGINEERING GmbH
Humbertogo
Re: vl-vbaload
« Reply #7 on: March 07, 2006, 09:38:57 AM »
Jürg
will give "Execution Error" that what i try to remove
acc ADN
;;; Issue      While executing a VBA macro from LISP, a statement that says "Execution Error"
;;;            is echoed on the command line.. My macro seems to work correctly, however, why
;;;            is the statement always there?
;;; The best way to run a VBA macro from LISP is to use the automation interface and
;;;            not the command function. Your AutoLISP code should look like the following:
Jürg Menzi
Re: vl-vbaload
« Reply #8 on: March 07, 2006, 10:32:27 AM »
Is the dvb in a folder of the acad environment?
Or
Probably you've an error in the vba code... can you compile the project?
« Last Edit: March 07, 2006, 10:38:37 AM by Jürg Menzi »
Humbertogo
Re: vl-vbaload
« Reply #9 on: March 08, 2006, 01:20:17 AM »
The dvb  file is finding in the support files path
my vba project have not error
Jürg Menzi
Re: vl-vbaload
« Reply #10 on: March 08, 2006, 02:08:35 AM »
I'm finished with my knowledge... :-(
You may post the dvb to check this behaviour...
Chuck Gabriel
Re: vl-vbaload
« Reply #11 on: March 08, 2006, 08:17:13 AM »
You can try putting (arxload "acadvba.arx") before the line where you load your dvb.  It's not likely to help, but it's certainly worth a try.
Jurg is correct though.  We need more pieces of the puzzle before we can offer anything really helpful.
Humbertogo
Re: vl-vbaload
« Reply #12 on: March 08, 2006, 09:38:34 AM »
This is the code what i use.
I copy the dvb file in to start in Folder and it working well (DWGPREFIX )
But when i copy the file in another folder in the support file search path
i get the err
Command: (RunVBAMacro "MsgBoxHello.dvb" "MyTestProject.MyModule.TestMacro")
; error: Automation Error. Problem in loading DVB file
(defun RunVBAMacro (dvbfilename vbaMacro / acadApplication dvbfile)
 ;; Load ActiveX
  (setq acadApplication (vlax-get-acad-object))
  (setq dvbfile (findfile dvbfilename))
  (if dvbfile
   (progn (vla-LoadDVB acadApplication dvbfile)
      (vla-RunMacro acadApplication vbaMacro)
   );progn
  (if acadApplication
    (if   (null (vlax-object-released-p acadApplication))
      (progn (vlax-release-object acadApplication)
        (setq acadApplication nil)
Jürg Menzi
Re: vl-vbaload
« Reply #13 on: March 08, 2006, 10:47:18 AM »
That's all what you have to use:
(defun RunVBAMacro (dvbfilename vbaMacro / dvbfile)
 (if (setq dvbfile (findfile dvbfilename))
  (vl-vbarun (strcat dvbfile "!" vbaMacro))
Call:
(RunVBAMacro "MsgBoxHello.dvb" "MyModule.TestMacro")
Note:
Don't use the project name...
And
How about the rights in this folder?
« Last Edit: March 08, 2006, 10:51:59 AM by Jürg Menzi »
Humbertogo
Re: vl-vbaload
« Reply #14 on: March 08, 2006, 11:31:44 AM »
The code is only working when i copy it in to the acaddoc.lsp..
but not when i load it as file (RunVBAMacro.lsp).!!!
